1978 - 1996 Big Bronco
Window Motor Install
Old Mar 22, 2004 | 12:04 PM
Bronco-Red's Avatar
Bronco-Red
I HAVE A 92 FULL SIZE BRONCO , TOOK RIGHT SIDE DOOR
PANEL OFF TO CHANGE OUT WINDOW MOTOR , "WOW"
CAN ANYONE TELL ME HOW TO OR WHERE TO START TAKING
IT OFF , LOOKS LIKE IT HAS RIVETS OR SOMETHING IN IT........
Old Mar 22, 2004 | 12:43 PM
oregonian's Avatar
oregonian
This is how I got the motor out of my '87. There are 3 bolts that hold the motor in place. One of them should be in plain view, and fairly easy to reach w/ a wrench. The other 2 are hiding under the door sheetmetal. Mine had two indentations (almost like center punch marks) at the two spots where the bolts were located. All I had to do was drill through these indentations with a bit big enough bit to allow me to get my socket through the hole and to the bolts. Not sure about ones with rivets, I know my regulator is riveted in, but not the motor. If it is though, I would think it would just be a matter of drilling the rivets out, and replacing them w/ bolts. Hope this helps.
Old Mar 22, 2004 | 02:14 PM
MRG_86_AG's Avatar
MRG_86_AG
At least on a '93 F150: Drill out the holes as mentioned in the above post and leave the rivets alone. If it's not too late, it's possible that you don't need to replace the entire motor, just replace the 3 neoprene gears inside. Either way it's easy and not expensive.
Clem's Cousin
Sep 29, 2014 03:54 PM
Vulcan420
May 11, 2009 11:46 PM
96broncoXlt
Jan 20, 2007 03:58 AM
Mulletwagon
Jun 12, 2006 11:28 AM
