Sponsored by: Real Truck
2" Lift
Old Aug 4, 2000 | 05:51 PM
leaner48's Avatar
leaner48
2" Lift
Would like to lift the front of my 99 F-250 4x4 supercab approx. 2"--front only. any ideas, what kit to buy, difficulty installing, cost etc. ?
Old Aug 5, 2000 | 08:52 PM
rob_n_houston's Avatar
rob_n_houston
2" Lift
Superlift..
Read the post down a bit on the super duty message list. Starts out "I just spent 6 hours...by spaceace I think.
Rob
1999 F-250 SD CC V-10 4X4 XLT Lariat Red clear coat
Old Aug 6, 2000 | 12:52 PM
leaner48's Avatar
leaner48
2" Lift
If I read it correctly, he raised his truck both front and rear, sounds like he had a rough time of it. thanks
Old Aug 6, 2000 | 03:09 PM
spaceace's Avatar
spaceace
2" Lift
I only lifted the front end.
Old Aug 6, 2000 | 03:41 PM
caliv10's Avatar
caliv10
2" Lift
Hello SD pal,
If your going to just go 2" then super lift is the best. I have a 2000, F250, crew cab, 4x4, V10.
Typically the crew cabs are about 1" higher in the front to start with. After a lot of research I put the super lift 2" kit on the front and then went with 1" blocks in the rear to get the truck to sit level. The kit was not too hard if you know the little tricks to it which I know now, with the telephone help of the 4X4 shop who sold it to me. I could do it easy now. Just make sure you get the track bar relocator with whichever one you go with. Some people say that you don't need one with only a 2" lift, but what it does is puts added tention on your front end and pulls the axle to one side which also makes the ride stiffer as a result. I also put on 16.5 weld wheels with 35" tires which clears fine. Although if i had to do it again I would probably go with 3" in the front jusdt as far as looks go. But I'm happy with it. If you need any pointers let me know. Good luck. RS
Old Aug 6, 2000 | 08:55 PM
leaner48's Avatar
leaner48
2" Lift
Thanks for info, My '99 super cab sits lower in front than rear. I' d like to level the truck. I looked at a couple 2000 models at dealer, front end looks to be designed differntly than on the 99s. I also noticed they seem to sit higher in front than my 99. I don't care for the way mine seems to sit with front end going toward pavement.
Old Aug 7, 2000 | 10:39 AM
rob_n_houston
2" Lift
Maybe you can help me out regarding the blocks. What is the exact size of the one you replaced? Mine are 2 5/8". I'm looking for a bit more. And if you could tell me where you got the 1" blocks? From Ford?
Thanks,
Rob
rob_n_houston(No Email Addresses In Posts!)
Old Aug 8, 2000 | 08:13 AM
daywalker's Avatar
daywalker
2" Lift
[font size="1" color="#FF0000"]LAST EDITED ON 08-Aug-00 AT 09:14 AM (EST)[/font][p]If your looking for bigger blocks get the dimensions you have and the dimensions you want and go to a dodge dealer, their overload blocks are about 2.5" taller than fords, but everything else should fit.
Daywalker
92' F-250 4x4 351 4.10 5sp
Old Aug 9, 2000 | 10:24 AM
carbajal's Avatar
carbajal
2" Lift
SoCalAngler
Jul 14, 2014 09:52 AM
rews2
Apr 14, 2014 08:43 PM
Ratkat
Feb 17, 2013 12:32 PM
Dlasure2
Mar 9, 2012 12:50 PM
dairyplumber
1983 - 2012 Ranger & B-Series
Nov 9, 2010 04:34 PM
