Can you accurately tell how clean the inside of you engine is by opening the oil fill cap on the valvecover and peering through it. I ask because today I saw the exact same model, year, and engine as my car sitting in the shop. My car has 41,000 miles on it and when you take a nice shop light and look in the valvecover, the pushrods, rockers, springs, everything in sight is sparkling clean. Not one hint of varnish or sludge anywhere. The car that is like mine has 119,000 miles on it and when I opened the oil cap on this one all I saw was a ton of varnish on all of the rockers and pushrods. Varnish everywhere. Anyway so is this a good way to tell the condition of your engine internals?
Varnish or hard cruds inside the valve cover or on the OIL Cap or "710 Cap" hehe j/k, they are a sign that the engine is not properly maintained.
Probably the owner did not change his OIL at the right intervals and had caused the OIL to suffer "Black Death", cruds begins to form and starts to stick to the engine parts and block oil passage ways.
It might be cleaned up back again by using some engine motor flush. I usually use GUNK Motor Tune Up Flush. Use that right before changing the oil. You just add that oil flush to your existing oil and run the engine for 5 minutes and turn it off and drain all the oil. Put new oil in and do it again around 1,000 or 2,000 miles and hopefully the gunk and cruds have been cleaned by then.
I would test that truck by letting it IDLE for a couple of minutes, check all the gauges. Drive the truck at the highway at Full Throttle. Also, from stop (few traffic) try to accelerate the truck by letting the wheels spin. You can find out if it has a driveability problem. It might bog down, hesitates, knocking noise, etc. Once finished testing, put some newspaper underneath to see how much oil drips you got in there. Anyway, that's how I test a vehicle.
Often by 120,000 miles there is a slightly darkened look to the valve train components. I don’t believe this is a real indication of condition of the engine. If you see gunky slop then you can probably assume the engine has had a hard life.
Yeah with my vehicle at 41,000 the valvetrain looks brand new while the exact same engine in the exact same model vehicle at 119,000 miles had more than a "slightly darkened" look. The vehicle with 119,000 miles had a very dark brown valvetrain with varnish everywhere. It was totally unexpected when I opened up that oil fill cap. I've never had a vehicle look like that under the valvecover. But then again I change my oil at a maximum of 3 months/3000 miles, most of the time less than that. My oil usually is still golden color when it comes out.
gtm245; You may say this guy & his seafoam, but I use it in the oil & on all my mods the valve train looks imaculate & the use of
new use of shell rotella t 5-40 synthetic seems like it will help in
the clean dept also. Try some seafoam in the crank case & tell us
what you think? turbo ted
Originally posted by 78fordman Never heard of the 710 cap thing LOL.
Are you sure you have not never heard of the 710 cap story? or you are just pulling my string?
A customer went to an automotive parts store and was asking for a replacement 710 cap. The smartest clerk could not figure out what the customer is talking about. One clerk ask the customer to write it down.
When the customer was writting the word 710 cap, the clerk was looking directly at the opposite side. Looking at the word 710 directly from the opposite side shows the word "OIL".
That's when the clerk knew the customer was asking for a replacement "OIL cap".
Turbo ted, this valvetrain that is full of varnish is not my car. It is a customers car that is in our shop right now for some power steering problems. I was interested to see how his valvetrain looked compared to mine since it's the exact same vehicle and his has about triple the miles than mine so I took a peek. Anyway if you knew me there is no way I would let my engine accumulate deposits and varnish like that. (I guess I could suggest he put some Seafoam in the pan.)
BTW I have used Seafoam before and it's great stuff. Put some in the gas, put some in the oil, or pour some down a vacuum line to stall the engine and clean out the top end. MMO works pretty good too.
