Sea Foam and Me!
Sea Foam and Me!
Sea Foam is magic. I used it in every gasoline internal cubustion engine I have around this house: Cars, motocycles, mowers, pressure washer. The stuff is just the greatest to clean up engines which have fouling problems from old gasoline, varnish, etc.
But what about diesels? I'd like to dump a can of that stuff in my "just acquired" 7.3 P/S diesel engine (with 240K on it).
Any one have an opinion on the advisability of doing that?
I am of a differing opinion.
Sea Foam has a high concentration of isopropyl alcohol. That's part of the reason why it has the cleaning properties which are claimed. The problem is that it does a number on lubricity, which is essential for diesel engines. And of course trying to inject and burn alcohol has it's own inherent issues.
The 7.3L is more forgiving using such additives. Newer diesels are far less forgiving. However, consistent use does have the possibility of causing issues even with the 7.3L.
Ford does not recommend the use of such additives in the 7.3L or any others. A properly maintained truck should not have any need for such additives anyway.
That said, I've used Sea Foam on a generator that sat for a year with a carb full of old gasoline. It did work to clean out the gunk that had it idling like crap. Half a can and it was running like new.
But I'd never put it in a diesel.
I'm not exactly warm and fuzzy about the long-term effects of isopropyl alcohol on injector O-rings. It is a low concentration in a full fuel tank, so maybe it's relatively harmless.
I use additives that compensate for the fuel reformulation that took place in 2007 (Ultra Low Sulfur Diesel), since our trucks were manufactured at a time when that didn't exist. The products I buy add a little lubricity and raise the cetane level.
There are plenty of diesel fuel additives that clean injectors, add lubricity, and boost cetane. Actually, with the diesel we're running now, cleaning shouldn't be an issue. I remember when the ULSD came out, and even more when they started mixing Bio with diesel, peoples fuel systems were getting so clean that it was plugging up fuel filters. So, unless your truck sits a lot, I'd say a dirty fuel system shouldn't be a concern. I guess carbon could get on the injectors and mess up the fuel delivery to the combustion chambers. So, in those cases, a cleaner would help.
Well with my little knowledge on diesels I would never put any type of fuel additive that was designed for gasoline style fuel (even jet fuel) due to diesel engines needing lubrication derived from the fuel we put in them. I highly suggest and recommend using power source diesel fuel additive. It's approved for every type of diesel engine new and old, it will not void any warranty, it cleans injectors, keeps filter in good health, lubricates injectors and other vital engine components, and it even boosts cetane levels a bit. I usually put in a 16oz can with each tank it comes in a gray bottle. When the cold weather rolls on in I put the white bottle in from the same company. This is just my opinion it's your truck do as you see fit. Good luck man and welcome to the 7.3 family.
