Oil drain plug
Old Mar 21, 2004 | 04:45 PM
pophauler's Avatar
pophauler
Oil drain plug
A note to you guys that change your own oil, replace the stupid drain plug washer. I had a slow drip even after tightening it to spec. Went to Ford and got a $1.40 washer... problem solved! It was a ball plugging the hole with one hand and installing the plug with the other. Glad my dexterity is intact... lost only 1/2 a quart! You veterans probably know this already. Oh well, live and learn! Neil
Old Mar 21, 2004 | 05:28 PM
Sabow's Avatar
Sabow
LOL my third oil change I noticed the same thing - thanks for the post - was wondering what was going on
Old Mar 21, 2004 | 08:11 PM
SBV45's Avatar
SBV45
Get a Fumoto valve. Problem solved.
Old Mar 21, 2004 | 08:56 PM
Campfire1's Avatar
Campfire1
What is a fumoto valve?
Old Mar 21, 2004 | 09:03 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
SB45 will tell you
and by the way WELCOME to FTE
Old Mar 21, 2004 | 09:05 PM
IB Tim's Avatar
IB Tim
Welcome to you too..................Sabow.
Enjoy the company here it Ford land!
Old Mar 21, 2004 | 10:33 PM
Campfire1's Avatar
Campfire1
I think I'll just get the new gasket.
Old Mar 22, 2004 | 05:43 AM
SBV45's Avatar
SBV45
A Fumoto valve is a small brass valve. You replace the pan drain plug with it. See it at http://www.fumotovalve.com/. You can put a piece of tubing on it when you go to drain your oil and drain directly into gallon jugs and never spill a drop.
Old Mar 22, 2004 | 06:20 AM
Campfire1's Avatar
Campfire1
Thanks for the info on the valve. We have a valve something like that on our grader at work. It is -3 here this am, so I won't change oil right yet, and that will give me some time to look locally for a valve, maybe even Fumoto.
Old Mar 22, 2004 | 09:02 AM
"Luke" SdeS's Avatar
"Luke" SdeS
Used on my cars, also
And you'll be one very happy camper, once you've converted over to it. I've been also using them on my cars for over 25 years.......It makes it so much easier.
Mcrafty1
Modular V8 (4.6L, 5.4L)
Jul 5, 2017 08:01 AM
raven3
Jan 7, 2014 07:53 AM
blue1ton
15
Jul 28, 2009 09:26 AM
Bopper
Jul 12, 2009 08:00 PM
GEugeneS
29
Apr 25, 2008 10:16 AM
