oil drain plug torque
Old Apr 8, 2008 | 08:57 PM
GEugeneS's Avatar
GEugeneS
Does anybody know what to torque the oil drain plug to? I have had a very slow leak there since i bought the truck a year ago. Changed the oil the last time and used the same copper washer and it leaked pretty bad. Got a tip on this forum how to hook up a shop-vac to the filler tube and pull the plug without losing any oil so I replaced the washer with a brand new one. Same thing. About 1 drip every hour or two. I can't visually see anything wrong with the seat or the plug.
I hear they are selling plastic washers now. Would that be a better way to go in case there is some small imperfection on the seat or plug I just can't see. Any ideas would help. Thanks. Gary
Old Apr 8, 2008 | 08:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I always use German-Torque... Guut-en-tiight
Old Apr 8, 2008 | 09:05 PM
F350-6's Avatar
F350-6
I've always used the method Kris described. How tight do you have the bolt now?I personally don't trust the plastic washers, but if you already have the drain plug tightened up pretty good it may be time for plan B.
Old Apr 8, 2008 | 09:16 PM
powerstroke1869's Avatar
powerstroke1869
or just go with a fumoto drain valve and never have to worry about takin off that plug ever again
Old Apr 8, 2008 | 09:18 PM
GEugeneS's Avatar
GEugeneS
I always use Kris' method too, but it isn't working this time. I haven't put a torque wrench on it yet, but it's not hard to put a lot more torque on with a long wrench as opposed to using a 1/2" ratchet. I assumed the owner's manual would have a torque spec but I didn't find it.
I don't like using a drip pan and of course I can't park in a friend's driveway anymore.
(Make that Not hard to put a lot more torque)
Old Apr 8, 2008 | 09:22 PM
GEugeneS's Avatar
GEugeneS
i would assume that the Fumoto would also have some kind of washer to seal it and I could have the same problem. What type washer does it use. ?
Old Apr 8, 2008 | 09:28 PM
powerstroke1869
http://www.dieselsite.com/index.asp?...ProdID=33check em out
Old Apr 8, 2008 | 09:33 PM
HKusp's Avatar
HKusp
I just put the Fumoto on 2 weeks ago. I also had a small amount of oil on the plug despite the copper washer. I haven't checked it since the Fumoto install but it doesn't have a washer. If I get a chance before leaving for Smokin tomorrow I will look at it and see what I have got.
Old Apr 8, 2008 | 09:43 PM
GEugeneS's Avatar
GEugeneS
I appreciate your looking at the Fumoto install. Thanks!
Old Apr 8, 2008 | 10:24 PM
mybigredford's Avatar
mybigredford
your problem of it leaking is because you didnt use a new copper washer when you changed the oil, i know this from expeirence because it happend to me, and it didnt matter if i crawled under and gave the plug a 1/4 more turn it would still leak. you must always use a new washer evey time. or like others say, get a fumoto
Old Apr 8, 2008 | 10:34 PM
jdecker88's Avatar
jdecker88
Amen to that, I got mine and I just used Kris' method. I have not noticed any oil dripping from my plug and it has been on 4 months.
Old Apr 8, 2008 | 11:03 PM
nhill2090's Avatar
nhill2090
go to your auto parts store and buy a washer. i got one with the rubber on the insdie, works great for about 10K so far.
If you put a vaccuum over your oil fill in your valve cover, you wont lose much oil when you change the washer
Old Apr 8, 2008 | 11:35 PM
WMRiceman's Avatar
WMRiceman
My fumoto drain plug came with a washer. Blue and looks to be made out of a hard rubber.
Torque specification for the oil drain plug is 28 ft lbs.
Old Apr 9, 2008 | 08:04 AM
GEugeneS's Avatar
GEugeneS
I'll try the 28 lbs first, then if that doesn't work look for a more pliable washer. thanks for the number.
gary
Old Apr 9, 2008 | 10:42 AM
HKusp's Avatar
HKusp
Thats right I forgot. I am going to go look underneath right now. I will be back.
