1978 - 1996 Big Bronco
Swapping T-cases
Old Mar 21, 2004 | 09:37 AM
Jimmy Dean's Avatar
Jimmy Dean
Swapping T-cases
my truck
89 bronco, 302 w/ a C6 push button T-case
his
94 bronco, 351W w/ a E4OD tranny, lever T-case
will my T-case be able to go into his truck? straight bolt in or equire some modification?
Thankyou.
Jimmy Dean
Old Mar 21, 2004 | 11:52 AM
tite4x4's Avatar
tite4x4
Just curious on the 89, I use to have an 89 with 302 and an AOD, isn't that tranny an AOD instead of C6?
The T-Case might bolt up correctly. But again Just curious as to why? From what I have read and heard the Automatic, push button T-Case, has been somewhat unreliable. With the manual shifter of T-Case at least one would definately know when and what gear the T-case is ingaged.
If you do decide to go with that swap, you will also need to take all the switches and wiring for it and put it into the 94.
Old Mar 21, 2004 | 03:40 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Just thinkin of that swap is just asking for problems bro.
Stick with the manuel t-case, you'll love yourself later for it.
Old Mar 21, 2004 | 11:29 PM
Jimmy Dean's Avatar
Jimmy Dean
No my bronco is a parts truck his T-case is toast, (the manual) he needs a new one and does ot want to spend the 900 bucks for a new one, or the 350 the junk yeard wants.....that is why I am asking....and no my 89 has a C-6 on it according to both the code on the door and the number of bolts on the pan. and the lack of overdrive......well it says on the gear indicator that it has an overdrive, but it is only 3 gears.
Old Mar 23, 2004 | 05:39 AM
Jimmy Dean's Avatar
Jimmy Dean
bump
Please, I need a real answer to my quistion, will they swith out without modifications or computer work or serious rewiring?
Can the T-case in my bronco actually be outfitted with the lever instead actually?
I know he said taht his T-case does have a motor in/on it for the button activation so would it also go vice-versa?
Please
Jimmy Dean
Old Mar 23, 2004 | 01:31 PM
BroncoRoadKill
Well, you would have too swap out the madual, buttons, wiring harnesses, and anything else I may be missing. anyway, I will get messy and it will take days too figure it out.
Old Mar 23, 2004 | 05:57 PM
steell's Avatar
steell
How about just opening the case and swapping the internals?
Pretty much everything inside the case is the same.
Blue Rebel
Feb 13, 2014 09:25 AM
Fordman96
Oct 15, 2011 03:19 PM
blowerbelt32
Jul 14, 2010 05:30 PM
ErrorS
Oct 19, 2009 05:57 PM
SouthPCraz
Jun 10, 2003 08:28 PM
