Oil & Lubrication
Recomendations
Old Mar 24, 2004 | 06:15 AM
  #31
jschira's Avatar
jschira
Originally posted by BlueRanger94
Come on.... there is no way to really know anything about Walmart oil since they publish no information about it.
You are correct that Wally does not publish anything, but people sent new, virgin oil samples and used samples in to Blackstone. That is where this information comes from.
I also know that the ST oils in Texas and 10 surrounding states are made by Shell at its plant in Houston. I also know that the ST recipe is the same recipe used for all the other comparable oils made at the plant. This information was posted by someone who works at the plant and has seen (with his own eyes) ST bottles running down the line, and confirmed the recipe with plant chemists.
So yes, I (and you) really do know something about ST oils.
Old Mar 24, 2004 | 12:52 PM
  #32
BlueRanger94's Avatar
BlueRanger94
I think the statement above proves my original point. The words "comparable oils" mean that there are different levels of oils produced.
So spending a few cents more could get you a little more protection.
Old Mar 24, 2004 | 01:26 PM
  #33
jschira's Avatar
jschira
No, it means 10w-30 versus 10w-30.
You can't compare a 10w-30 to a 20w-50 for any brand of oil. The base oils/additive packages will be different.
Old Mar 24, 2004 | 02:58 PM
  #34
BlueRanger94
No, I mean 10W30 versus 10W30.
Your original statement implies that they produce different levels of oils within each grade. As in all the level one 10W30’s get a mix and all level two 10W30’s get another mix.
If you meant that all 10W30's get the same mix I am sure you would have said that, so the above is how I interpret what you said.
Old Mar 24, 2004 | 03:28 PM
  #35
jschira's Avatar
jschira
OK, I meant what you think that I mean, not what I think that I meant.
Let your imagination run wild.
You are also in denial/anger, which is typical in people the first time that they find out they have been paying too much for "premium" oil.
1. Denial.
2. Anger.
3. Acceptance.
You need to move on.
Old Mar 24, 2004 | 07:39 PM
  #36
towboat's Avatar
towboat
You are correct that Wally does not publish anything...
I wonder why...
Perhaps it's because if Walmart did publish technical specifications for their SuperTech oil then the oil would legally have to consistantly meet those specs.
So Walmart expects customers to buy SuperTech to protect their very expensive engines but they refuse to publish any information on the oil.
That says all I need to know about Walmart/SuperTech.
Manufacturers of quality products publish this information.
Old Mar 24, 2004 | 08:06 PM
  #37
BlueRanger94
1. Denial.
2. Anger.
3. Acceptance.
I think your nuts!
You feel you have the only answer.
Old Mar 24, 2004 | 08:11 PM
  #38
Rockledge's Avatar
Rockledge
Originally posted by towboat
I wonder why...
I believe you have a point. But Walmart is a retailer, not a manufacturer. And I would think that any retailer that does not make and market its own oil, but instead relies on 3rd party low-bidders to supply an oil that meets a certain minimum set of standards, would be reluctant to publish that set of standards. Primary reason is that the standards are by nature only indicative of what is acceptable, not what is actually being offered by the current high-bidder/provider. So to publish the standards would be to possibly give the wrong impression to the public of what the actual product on the shelf is comprised of, at any given time.
To use an analogy, I don't recall ever seeing Sears publish the minimum specs of its Craftsman line of tools, which are similalry made and provided by 3rd party tool makers who essentially bid for the right to have Sears put the Craftsman name on them and sell them in the Sears store chain.
P.S. Lets keep this thread on track guys, no more comments directed at anyone personally...
Old Mar 25, 2004 | 05:42 AM
  #39
towboat's Avatar
towboat
Here's a better example.
Ford's Motorcraft oil is manufactured by an outside company for Ford. Go to www.motorcraft.com and you can read the specs for each weight of motor oil that they offer. The information is quick and easy to find even though the oil is from an outside supplier.
Quality companies tell you what you are buying, with SuperTech it looks like you just have to trust them...
The engineers at Ford that designed your truck's engine define performance specs that oil must meet (example: WSS-M2C153-H for the 5w20 gas engine oil) so there is no doubt when buying Motorcraft it meets those standards.
Old Mar 25, 2004 | 06:06 AM
  #40
jschira's Avatar
jschira
Yes, I agree. Sorry.
As far as oil recommendations go, you need to use what makes you feel comfortable. If you are a brand name buyer, stick with a brand name. They are all pretty good, and you will not go wrong with any of them. Wait for someone to have a sale and stock up. PepBoys has QuakerState for $0.79/qt. with mail-in rebate. Valvoline is $0.89/qt. with rebate.
Personally, I use ST in my gassers. I have a Wally Grocery Store right down the street and my wife can pick up 5 qts. when she does her grocery shopping. No need to make a special trip or keep a large stockpile laying around. Always there when I want it. Always $0.84/qt.
Old Mar 25, 2004 | 07:33 AM
  #41
Rockledge's Avatar
Rockledge
Ford and Walmart - Two different animals, IMHO.
Ford is a manufacturer of vehicles which absolutely require motor oil and other fluids to function properly and last a reasonable amount of time. Ford's fortunes are so much more dependent upon oil quality and standards then Walmart's are. Ford spends big dough on R & D with respect to motor oil for a reason. The fact that Ford's own engineers design the specs for motor oil, extensively test the motor oil, and ultimatley bless the motor oil for use in Ford vehicles pretty much puts it in perspective. If Ford wasn't getting their oil from a 3rd party provider (which I assume to be true), then Ford would be refining it and blending it themselves out of necessity.
Recall that you've never seen any brand except Motorcraft on the shelf when you go to your local Ford Dealership. But when you go to Walmart, there are at least a dozen different brands to choose from. That's another good indication of the differences between how the two companies view the role of motor oil in their overall business plans.
I'm not defending Walmart here, just trying to express a point.
Old Mar 25, 2004 | 09:06 AM
  #42
TallPaul's Avatar
TallPaul
FWIW: Last Sept I got a coupon flyer from my local Ford dealer (Village Ford, Dearborn MI). Their "best" oil change offer was listed as "Valvoline Semi-Synthetic DuraBlend." Now if the Ford dealer (and these flyers probably were developed by the Ford Motor Co for dealer use) says Valvoline Durablend is best then it must be as good or better than Motorcraft oil. So I wonder if the coupon flyer a sort of endorsement by Ford of Valvoline Durablend?
Old Mar 25, 2004 | 09:47 AM
  #43
jimandmandy's Avatar
jimandmandy
These flyers may be developed by the bulk oil supplier (Valvoline in this case). Most dealerships get bids on bulk oil from local distributors and dont use the manufacturers brand unless you pay extra. Pennzoil/Quaker State is the most common bulk oil at dealerships here. Valvoline is what you get at my local BMW dealer unless you specify BMW oil and pay extra.
Jim
Old Mar 25, 2004 | 11:13 AM
  #44
TallPaul's Avatar
TallPaul
Thanks Jim. Makes sense. Best oil for whom? The dealer's cost margin, presumably.
Old Mar 25, 2004 | 12:36 PM
  #45
jschira's Avatar
jschira
Some of you are giving far too much credit the "chemists" at the oil/engine companies. Engine companies just set performance specs, what the oil has to do. Engine companies do not specify the quality of the base oil or the additive package.
As far as the oil companies go, the following was posted by someone with decades of experience in the oil industry, including several years spent as a motor oil blender:
Just in case you are not aware of lubrizols part in the industry - they manufacture most of the additive used by most of the lube industry in the world. There is SOME proprietary chemistry in the odd motor oil, but for the most part, the OEMs dictate a new need, the industry tries to modify its formulations to meet it, and lubrizol is right in the thick of all of the science and chemistry. When there is a new spec, lubrizol has to make a slightly different version of the additive package to suit the different base oil charactaristics of the very few refineries that actually make the base oil stocks, and the brand owners just buy the package from lubrizol, blend it with their base oil and a viscosity modifier (more often from Shells selection) and slap their name on it.
Most (not all) of the big brand names that you see on the shelf just buy the stuff from lubrizol and do a cake mix thing to blend up their product, the bulk of the actual science goes on at lubrizol.
The only significant difference between motor oils is the label on the bottle.
