Please Help Me."Big trouble"
Old Mar 20, 2004 | 09:30 PM
rangerproject's Avatar
rangerproject
Question stored truck restart suggestions
I'mgoing to restart a 1995 ranger 6cyl. engine. tranny died at 74k $1500 later it lasted 12,951 mi,just past warranty. Need to restart engine to move inside after several years.what's the best way to lube upper engine parts to prevent scoring &cam wear.
Old Mar 21, 2004 | 12:16 AM
el conquistador's Avatar
el conquistador
I'll bet if you post this in the oil and lube forum they could help you more.
Old Mar 21, 2004 | 05:04 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Welcome to FTE.
Here's my thoughts on it. I'd pull all the plugs and with an oil can squirt in 2-3 shots of your favorite motor oil. Crank the engine a bit with the plugs out. Then put another shot of oil in each hole and reinstall the plugs. Crank it a bit (like 3-5 seconds) with the ignition disabled and let it sit for the night. Next day, check the oil and coolant levels and fire it up. Move the rig as needed but follow up with an oil/filter change before you really go out and hit the road. You really don't have to worry about cam wear; the cam will be lubed by oil being slung up there as soon as the engine starts and what oil is left there now will be enough for the first few seconds of run time. You do run the risk of all of this oil fouling the plugs so be prepared to replace them.
Old Mar 22, 2004 | 05:00 PM
rangerproject
great advice
thanks'cowboybilly9mile,had same idea but wasn't sure it was enough.Will go to other site also.first timer so I'm not to up on the site,sure is a ton of info. spent hours reading &learning.T&CJ rangerproject.
Old Mar 22, 2004 | 11:13 PM
el conquistador
good luck.
Lastwagen
6.7L Power Stroke Diesel
Apr 14, 2013 07:55 AM
woot824
1997 - 2003 F150
Sep 3, 2011 10:34 PM
Lolat590
16
Jul 8, 2011 12:47 PM
dlbrooks2658
New Member Introductions
Nov 21, 2007 01:19 PM
gdavis2265
Apr 26, 2003 01:42 PM
