White Smoke!!!!!!!#$%&##!
Old Apr 24, 2003 | 09:32 AM
gdavis2265's Avatar
gdavis2265
This is a weird one guys, please give me some advice.
Here's the symptoms:
Shut off the engine after warmed up, wait over 10 minutes and restart: White smoke cloud out the exhaust (Reeks of fuel)
Shut off the engine after warmed up, wait over 60 minutes and restart: No smoking whatsoever, no fuel smell
Shut off the engine after warmed up, wait less than 5 minutes and restart: No smoking whatsoever, no fuel smell
Start the engine cold: No smoking whatsoever, no fuel smell
Engine burns no oil.
What's the deal? Only smokes between 10 min and 1 hour at restart
Old Apr 24, 2003 | 09:54 AM
Vampiro's Avatar
Vampiro
if its white its antifreeze maybe a gasket is gone and when it warms up it expands or something to that effect
Old Apr 24, 2003 | 10:03 AM
gdavis2265's Avatar
gdavis2265
yea, I thought about that- 2 things though:
1) why does it smell of fuel?
2) if it was antifreeze, wouldn't I see smoke all the time/or some other time?
Thanks for you input, this thing is driving me crazy. I don't think it did this with the old 1bbl carb. Also maybe it has something to do with the elec. choke, or vaccuum or something.
Old Apr 24, 2003 | 10:04 AM
millertime300's Avatar
millertime300
Do a compression check, sounds like your head gasket died.
Old Apr 24, 2003 | 10:10 AM
gdavis2265's Avatar
gdavis2265
thanks guys, I think maybe I will try to retorque the head- can someone send me a .jpg of the torque sequence for the 300 head- and the torque values. If somebody has them handy.
Thanks
Old Apr 24, 2003 | 10:11 AM
couleeman's Avatar
couleeman
How warm is warmed up?
My GMC will put out what appears to be white smoke if I only run it for about 10 minute to 20 minutes at a time. What it actually is is steam from moisture built up in the exaust system as my GMC doesn't get run more than 4000 miles a year.
The solution I was told was either drill a couple of drain holes in the muffler or run it for about an hour once a week.
The unburned fuel might be the fuel smell.
Another note, Watch your antifreeze levels close, just incase
Old Apr 24, 2003 | 10:12 AM
gdavis2265's Avatar
gdavis2265
oh, also- if it is the gasket, what is the best replacement for it. I will try a compression check- what should the accceptable psi be on the cyls? Within 10% of each other?
Old Apr 24, 2003 | 10:13 AM
gdavis2265's Avatar
gdavis2265
it's a daily driver, so It gets ran alot to fully warm the engine
Old Apr 24, 2003 | 10:14 AM
couleeman's Avatar
couleeman
Well that throws out the easy and cheap problem? Good luck
Old Apr 24, 2003 | 10:22 AM
gdavis2265's Avatar
gdavis2265
hey guys, what about fuel pressure - seems like if it sits over an hour the pressure bleeds off and won't smoke. But if I come out ½ after shutting the engine off the pressure is still there and its flooding. Just a stab in the dark
Old Apr 24, 2003 | 08:12 PM
rhetor's Avatar
rhetor
mmm could be that, but I wouldn't think that it would take that long to bleed off pressure, and if a regulator is shot, it'll probably do it constantly, because they really don't warm up too much. It could be that its sticking perhaps... I would check fuel pressure.
Sounds to me like a head gasket. Double check to make sure its fuel and not antifreeze
Old Apr 25, 2003 | 12:50 AM
mikefraz01's Avatar
mikefraz01
ive always found with a head gasket problem my dipstick gets spicy brown mustard syndrome, i only read about threee posts to your question, so maybe you allready found the problem, but check the dipstick if thats what the crew thinks you have a problem with..... makes sense about the swell thing though, i read about someones prob with their trans shifting hard only in rainy weather so i guess weather and temp changes def do affect things
Old Apr 26, 2003 | 01:42 PM
billyb's Avatar
billyb
You have to do a compression check and dipstick check. Depending on where gasket is leaking, you may get water in cylinder and/or in oil.
Unfortunately you may even have a cracked head or block.
matowns21
Dec 26, 2011 08:15 PM
jcarr922
Jun 8, 2006 03:41 AM
jb1390
35
Feb 16, 2006 10:19 PM
ditch witch
Feb 4, 2006 07:44 AM
diskguy
49
Nov 30, 2005 10:18 AM
