Higher compression heads now I got falve float
Old May 14, 2004 | 09:30 PM
Lee Lichterman's Avatar
Lee Lichterman
I am not sure I am convinced on the timing issue. If this is EFI, then the timing should be automatic and not very adjustable. It is set to a base value if I recall correctly and then the computer takes over from there. You can adjust all day long and the computer will just over ride your setting unless you go waaaay beyond the normal envelope.
My bet would be on the springs or else a chip change since the computer might be getting confused by the increased flow.
Good Luck,
Lee
Old May 16, 2004 | 09:47 AM
FatzFord's Avatar
FatzFord
The Noise
Turned out to be a rod bearing, sollution for now is 40 wt oil, I have a short block being built..
johnf3504x4
Dec 7, 2013 09:56 AM
sdetweil
Oct 23, 2008 10:03 AM
longjohn69mustong
May 10, 2004 06:37 PM
FEina52F1
Feb 4, 2002 05:17 PM
bigred
Feb 14, 2001 04:47 PM
