valve spring compression
Old Feb 4, 2002 | 12:22 AM
FEina52F1's Avatar
FEina52F1
Old Feb 4, 2002 | 02:17 PM
dzjammer's Avatar
dzjammer
My current cam has .510 lift for int. and exh. The springs were new when I put it in. The cam I want to replace it with has .460/.480 lift, is there anything I'm missing or can I use the same springs for my new cam?
Old Feb 4, 2002 | 02:42 PM
Ratsmoker's Avatar
Ratsmoker
Shoudl be absolutely no problem. Lower lift doesn't always mean lower required spring pressure but if the durations aren't extremely different it should work great.
Old Feb 4, 2002 | 05:17 PM
FEina52F1's Avatar
FEina52F1
Test the springs and set them up as the cam card requests.
Dont forget to check coil,cap,guide bind
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
