Anyone here run stacks?
Old Mar 20, 2004 | 12:53 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Question Anyone here run stacks?
Just wanted to know if anyone liked the big rig look and put stacks on your truck.
Old Mar 20, 2004 | 01:14 PM
CAT_man_963's Avatar
CAT_man_963
Yea and does anyone have some pictures?? I've seen a few Dodges with stacks - but some Powerstroke out there has to have some stacks on it!!??
Old Mar 20, 2004 | 01:15 PM
Quadzilla's Avatar
Quadzilla
Well, yes and no. I do like the big rig look, but haven't put stacks on my truck. I didn't want to give up the bed space. I know a few guys that have stacks, and they sound great as well as looking good.
Old Mar 20, 2004 | 02:21 PM
fourstroke's Avatar
fourstroke
Stacks look sharp,for sure, but just think of where the soot gets blown on start-up. Not that I'm trying to rain on any parades.
Old Mar 20, 2004 | 11:53 PM
wannaburn's Avatar
wannaburn
I was thinking about doing stacks I sure would like to hear one done
Old Mar 21, 2004 | 12:22 AM
Go Aweigh2452's Avatar
Go Aweigh2452
I did it on a 54 Ford F100 and it was painful to do since it meant pulling the box back about 8" and then extending the bumper and rear axle (so the box fit on top of the wheels squarely). I am not sure it would require the same amount of effort on a newer truck but I for one will not do it again. Even though it was cool... If I did do it, I'd probably cut right through the bed instead of moving the bed back. Much easier and less work to accomplish.
Old Mar 21, 2004 | 08:23 AM
HeatStroked's Avatar
HeatStroked
Here's a site that has them;
http://www.stylinconcepts.com
Type In "Exhaust Stacks" in the Search
Old Mar 21, 2004 | 10:13 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Just a few pics I found on a quick search.
Old Mar 21, 2004 | 10:16 AM
cookie88's Avatar
cookie88
FTE Emeritus
I like this one...real clean.
Old Mar 21, 2004 | 11:05 AM
powerstrokin97's Avatar
powerstrokin97
just wonderning: after looking at that second pic. cookie, wouldn't you want to have the Y pipe pretty close to the center between the two pipes? Wouldn't the setup pictured blow more smoke out of the right stack because it would have a shorter distance to travel?
Old Mar 21, 2004 | 11:13 AM
cookie88's Avatar
cookie88
FTE Emeritus
On the few that I've seen in person I didn't really notice one stack smoking more than the other. You can't center the up pipe, driveshaft is in the way.
Old Mar 21, 2004 | 02:26 PM
Byrddog's Avatar
Byrddog
Guy i work with put a single stack up the pass. side.
He drives a 95 PSDjust cut a hole in the corner of the bed and ran it straight up.
Ill try to get some pics.
As someone else said, my buddies truck is white and the soot builds shows up fast.
Also the stacks i have checked out are the same as a muffler.
Im wanting to run a straight pipe.
Just my 2 cents.
Old Mar 22, 2004 | 12:00 PM
JL-Cowboy's Avatar
JL-Cowboy
Hey Guys- I put a 6" stack on my truck a while back. Just one out behind the passenger side of the cab through the inside of the bed, funds didn't allow for true duals or I would have put 2. It really sounds good, I love to roll down the back windows and listen to her purr, its a 6speed so when you really get after it and shift gears to turbo really sings. The 6" looks cool with black smoke bellowing out I will try to post pics.
Old Mar 22, 2004 | 03:20 PM
Jlower's Avatar
Jlower
There's a guy here in Tucson with a real nice set of stacks. He extended his frame enough to give him room for the stacks and heat shields. The exaust pipes go vertical right at frame height but are pushed to the edges of the cab. The shields start at the bottom of the cab qnd go all the way to the top of the cab. Originaly he just pushed back the bed but it looked funny offset on the wheels. I have to get some pics for you guys. Really a sweet big rig look.
I'm hoping to try this sometime down the road.
Old Mar 22, 2004 | 06:13 PM
johnsdiesel's Avatar
johnsdiesel
JL-Cowboy, how about a picture?
