Anyone here run stacks?
Old Mar 22, 2004 | 06:17 PM
eeglot's Avatar
eeglot
YES pics please!!!!!!!!
Old Mar 22, 2004 | 11:35 PM
wannaburn's Avatar
wannaburn
I would deffinetly love to hear one
Old Mar 23, 2004 | 06:02 PM
powerstrokin97's Avatar
powerstrokin97
Just one out behind the passenger side of the cab through the inside of the bed, funds didn't allow for true duals or I would have put 2
My 2 cents: Isn't my thinking correct that as long as you run a turbo, then you cant really have what would be called "true" duals? So, I would think that a much better sound could be achieved through one stack opposed to two.
Old Mar 23, 2004 | 10:03 PM
fourstroke's Avatar
fourstroke
More stacks equals more sound, same as putting more than one speaker in your stereo system.
Old Mar 23, 2004 | 10:52 PM
wannaburn's Avatar
wannaburn
Does anyone have a sound clip of this.
Old Mar 24, 2004 | 05:31 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
How about 1 stack?
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Mar 24, 2004 | 07:29 AM
farmb0y's Avatar
farmb0y
What kind of boost does that turbo put out??? That's more like something you'd see on a tractor, and it still looks bigger than a lot of those!! I'd love to hear that thing spool up, that's for sure! Do you have a hood that fits over that, or is it left exposed?
Old Mar 24, 2004 | 10:56 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
No hood yet, I'll work on that this summer. The turbo visible is an HT4B from a 400 Cummins (1000 c.i.) and is #3 in the staged system. Mid turbo is HT3B from a 350 Cummins (866 c.i.) and the oem Garrett is still in there, too. I did this mainly for experimental reasons to see how it all works. Boost is pretty good, but running WAY lean now, need to get bigger injectors. Pulling off #3 for a little while, but I'll play some more with it this summer.
Sounds like a lear jet taking off, too.
Pic of all 3:
__________________
Old Mar 24, 2004 | 11:22 AM
johnsdiesel's Avatar
johnsdiesel
What other mods are you running?
Old Mar 24, 2004 | 12:15 PM
13hondacr250's Avatar
13hondacr250
:-staun :-staun :-staun :-staun :-staun :-staun
WOW! Can I ride in it? I bet that thing once dialed in will really go!
Last NOV I bought a Ram 2500 Cummins and it had dual 4" stacks coming out the bed. I removed them due to the soot and I need the bed space.
I gave them to my buddy to put on his Cummins 2500 flat bed. He ended up putting on 5" stacks. Looks really good. Sounds good too. I got his truck today and boy can you ever hear the turbo sing.
What I really want to do is make mine smoke a lot of black when I want it to. I call it anti-ricer air.
Old Mar 24, 2004 | 05:45 PM
eeglot's Avatar
eeglot
Jesus H tapdancing christ................
That is the wildest thing I have seen bar none............I saw in person a twin turbo corvette up close, and I thought that was unreal, and the car ran high 7s in the 1/4 mile and he let off at half track.............................but this thing OMFG
My hats off...........this takes the cake big time. You HAVE to keep us posted on its progress!
all the best
Eric
Old Mar 24, 2004 | 09:40 PM
FoMoCo136's Avatar
FoMoCo136
You been breathin too much a dat smoke,,,,,,,,,) I love that,,,,,
Old Mar 24, 2004 | 10:00 PM
  #28
DCClark's Avatar
DCClark
Neat setup I must say, but forgive my ignorance. With that setup the way I understand it, the largest turbo is the intake, you have to suck air in past the #3 turbo, to the #2 turbo, down to the #1 turbo to get initial boost, which in turn is creating more work, but feeding air intake speed to aid the spooling up of #2 and #3 turbo. Once the 2nd or 3rd (or both) are spooled and pushing air down to the first turbo, you are limited by the #1 turbos CFM and intake size. Seems like your trying to shove a pen into a pin hole. No offence, I think it is really neat, especially for experimentation.
Old Mar 25, 2004 | 05:43 AM
  #29
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Boost is PSI, not CFM. I'll play with CFM's with just using the 4B and 3B this summer. For now, I want max boost, and it goes like this: Exhasut exits engine and spins #1 turbine (oem turbo), then to #2 turbine, then to #3 turbine, then out. Intake: From filter into #3 turbo and gets compressed and sent to #2 turbo, gets compressed again and sent to #1 turbo which compresses it again and shoves it into engine.
The oem turbo works best around, say 30 psi. If you feed that with 15 psi from the #2 turbo then the engine sees 45 and the oem turbo is working in it's optimum range, and the #2 turbo is too. Then feed #2 with say 15 psi, bumps output of #2 up by 15, etc. and the engine soon sees 60 psi and all the turbos are happy.
All this without really getting on the fuel very much. Get on the go pedal and 100 to 120 psi should be possible.
__________________
Old Mar 25, 2004 | 07:36 PM
  #30
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
"should be possible". Does that mean you are on stock headgaskets still, or stock injectors? I took the statement to mean you're not quite ready to find out what she'll really do.
