Removing lug nut cover
Old Mar 20, 2004 | 09:33 AM
daveplot's Avatar
daveplot
Last time I rotated my tires I used a screwdriver covered in a towel to pop off the lug nut cover on the wheels. Doing this ended up digging into the wheel and cover a little.
What is the best way to remove these stuborn covers without messing them up or the wheel?
Old Mar 20, 2004 | 10:53 AM
tsdrallyer's Avatar
tsdrallyer
I use a small nail puller and pry up on opposite sides. Be glad they are tight. I lost one on a trip recently and it was $30 to find a scratched replacement for it at hubcaps.com
Old Mar 20, 2004 | 04:17 PM
Troll45's Avatar
Troll45
You can use a cotter pin puller. Not the screwdriver type with the curly pigtail looking end. But a heavyduty type that you hit on the other end with a hammer to pull cotter pin with. Just use it to pull the cap off (NO HAMMERING NEEDED) or prying. Snap-on tools sells these. Dome seal pullers will work with a little modifying. Or find a heavy piece of flatstock metal 3/8 inch wide and bend a hook on one end to fit under cap in slot and a hook on other end to pull with.
Old Mar 20, 2004 | 07:33 PM
cairatti's Avatar
cairatti
I use a large flat head screwdriver with a few pieces of electrical tape around the end. Just pry slowly at several different points and you should be OK.
Old Mar 20, 2004 | 08:33 PM
buzzard's Avatar
buzzard
I use the smallest pry bar I have in a set of four that are the screwdriver type. I cover the tip in masking tape to prevent scratches. Slip in the tip, rotate the wrist and off comes the cap.
Old Mar 20, 2004 | 10:10 PM
PaulC's Avatar
PaulC
I use cairatti's method. Always works.
Old Mar 21, 2004 | 07:07 AM
Petrol's Avatar
Petrol
so . . . did y'all lose the lug wrench that came with the truck? that's what I use . . . it has that nice soft plastic coated pry bar end . . .
Old Mar 21, 2004 | 09:59 AM
daveplot's Avatar
daveplot
I ended up using the lug wrench that came with the car to get the caps off. It worked on the first one, but after that the plastic started to flake off. It still screwed up the rim/cap some.
I went out and got the rubber stuff that you use to put grips on tools and dipped a screwdriver in it three times so I have a nice rubber pry bar for next time.
Old Mar 21, 2004 | 12:33 PM
Matt03Expy's Avatar
Matt03Expy
I made a sort of U shaped puller out of strap iron and then coated it with plastic. This engages both "holes" at the same time
and I just yank the cap off.
Old Mar 21, 2004 | 02:48 PM
buzzard's Avatar
buzzard
Hey Petrol, where have you been?
Where the hell is the lug wrench??? All I've ever used is my floor jack and air impact to jack up and remove wheels.
Old Mar 21, 2004 | 02:53 PM
daveplot's Avatar
daveplot
That's what I used...the impact wrench sure does save a lot of time.
I have a small floor jack, but my neighbor has left his big $200 floor jack at our house... I think he forgot about it. So I've been using it.
Top_Speed1
Mar 13, 2017 07:14 PM
Azuretruck
Aug 31, 2016 02:01 PM
cmcstotts
2009 - 2014 F150
Aug 29, 2013 08:56 PM
bkcowboss
Oct 6, 2008 01:47 PM
DS02F250
Dec 18, 2004 06:29 PM
