REBEL_GTC
Try using this site http://www.sunrisefordfleet.com/factoryorders
You will need your order number. When i ordered my truck i was
able to track it through here as the dealer gave me the order number.
Hope this helps. I don't know if this works for others dealers.
How much did you pay above Invoice
Thanks for the site.
I'll give it a try once I get hold of my order number.
I paid 200 over invoice jeff was selling $950 below invoice if i'm not mistaken so I should have save at least $1150 I guess better luck next time
On Tuesday, it was "scheduled for production" for this week.
On Wednesday, it was "released" "from a foreign plant"
Today, it's on a train.
I guess that released must mean released from the production line.
Who cares, it's finally on the way!
Mine was produced Monday, released Tuesday, and still (Friday) VOPC says 'released from foreign plant'. No indication that it is en route yet. What gives??
rebel-
you need the order# or VIN, dealer code, year model, and body style to check status with the VOPC.
Be glad to check for you if you have this info.
I'm assuming the body style would be U17? or L24? I dont have my order info here to check which #'s are which. Also, I would need your order #. This should be 4 digits, or letters. Not sure if it is uniform, mine is letter, number, number, letter.
If you're looking for the same info as rebel, go back a few posts and see what info VOPC requires. If you have it, it's easy to call and find out. I believe the phone number is located in this thread somewhere. If not, I know i've seen it posted in quite a few different threads. If you still need help, I'll be glad to do what I can.
Vehicle Order Processing Center
<!-- 1(800)962-3746 -->
you'll need:
dealer number (from VOC)
order number or VIN (order number is easier)
body style code (W14 for SuperCrew)
model year (presumably 2004)
call, listen to prompts, speak up slowly and clearly
good luck!
I tried to locate my F250 ordered thru Jeff today via VOPC. The gal that answered
the 800 number said it was for dealers only and referred me to
a customer service number and they couldn't find anything....
Guess I'm outta luck....
PSD 6.Oh!
