Sponsored by: Real Truck
need help wiring sander
Old Jan 11, 2015 | 06:09 PM
joeycyph56's Avatar
joeycyph56
Im trying to wire a noreaster 8' elec V spreader for my buddy. He bought the spreader used so it came with no controller just 12 inches of 6 ga wire. my idea is to run a 6 ga lead off the battery to the sander and run another lead off the upfitter switch to a 60amp relay to switch the sander on/off. The only specs I can find says that it has 60 amp startup draw and 40 amp running draw. My question is what I am proposing to do correct or is there a better way to wire this. Thanks
Old Jan 11, 2015 | 10:25 PM
99f350sd's Avatar
99f350sd
Mine goes from the battery to a short run of heavy wire to a monster fuse then to the relay and off to the back. Sw the relay with your sw...The ground for the sander i don't remember where that went...I'd have to look to see if i went to the frame or the battery. I'm guessing the battery. I'll look tomorrow.
Dick
iam8up
Aug 3, 2012 02:14 PM
gectwo
Electrical Systems/Wiring
Sep 23, 2009 10:12 AM
kidoo
Mar 6, 2006 04:57 PM
matt f350
All Things Towing
Sep 17, 2004 12:38 AM
boroarke
Mar 22, 2003 12:55 PM
