Sponsored by: Auxito
Rear differential
Old Mar 19, 2004 | 04:39 PM
mjgolob's Avatar
mjgolob
Question Rear differential cover
I have a 01 SCREW and want a stonger, better rear diff cover.
Anyone have any good or bad experiences?
I am looking at the MAC product ... more expensive but looks bulletproof and increases the fluid capacity.
Also, can I be sure that I have a 8.8" rear or were there other options?
Are there different gear oils that I should consider, or just stick with stock recommendations. I tow more than I should with a 150.
Thanks
MJG
Old Mar 19, 2004 | 09:19 PM
ranger88a's Avatar
ranger88a
Most supercrews around here have 9.75 rear ends. As far as fluids go, I recommend factory, It's probably synthetic anyway. Just change it once in a while.
Old Mar 19, 2004 | 09:25 PM
LxMan1's Avatar
LxMan1
I think it depends on the package. 5.4L? Factory towing package?
The 8.8 cover is the same looking on both sides. The 9.75 Sterling rearend cover is kinda oblong. It isn't symetrical.
Old Mar 20, 2004 | 07:28 AM
JeremyH's Avatar
JeremyH
This is the strongest diff cover on the market:
http://www.4x4rockshop.com/scripts/p...idproduct=2191
Old Mar 20, 2004 | 08:21 AM
mjgolob's Avatar
mjgolob
5.4L 4x4 Tow package
Does the 975 on the tag mean the 9.75"
Tag:"L55 975 OL20"
It is oblong...
Old Mar 20, 2004 | 09:12 AM
ranger88a's Avatar
ranger88a
Should be 9.75.
Old Mar 20, 2004 | 04:37 PM
LxMan1's Avatar
LxMan1
3.55 limited slip 9.75 rearend!!
Probably says 3L55. The 3 is real close to the cover bolt.
Old Mar 21, 2004 | 11:44 AM
Multipierce's Avatar
Multipierce
The F150s with the 5.4L all have the 9.75" rear end. The ones with the 4.6L or the 4.2L all have 8.8". Just FYI.
Dube
Old Apr 6, 2004 | 10:48 PM
ford-fanatic73's Avatar
ford-fanatic73
use 75w140 if you a towing a lot and dont use a chrome cover it just builds excessive heat use alum with fins and a fill hole go to perfomanceproducts.com for a really nic cover that increases fluid capacity
zombiefied 247
Jan 22, 2013 11:23 PM
Headviking
Mar 22, 2010 01:12 PM
Momorris
60
Mar 20, 2008 03:28 PM
DeckedoutF150
Aftermarket Products
Oct 25, 2005 08:55 PM
Panzerbrumbar
Garage & Workshop
23
Dec 8, 2004 08:44 PM
