Front wheels spread out when backing up.
Old Mar 19, 2004 | 02:03 PM
Vin 95's Avatar
Vin 95
Question Front wheels spread out when backing up.
They either spread out at the bottom or in at the top but it is very noticable.Is this normal or is something wore out?Ihave jacked it up and checked the ball joints and they seem fine.:
Old Mar 19, 2004 | 03:38 PM
Rockledge's Avatar
Rockledge
I'm a little confused ...what do you mean by "spreading"?
Old Mar 19, 2004 | 04:04 PM
Vin 95's Avatar
Vin 95
The top leans in just like if the ball joints were about to go.I forgot to mention this is a 95 XLT reg cab 2wd.When i back up in a parking space,and look at the truck from the front it is very noticable,if i pull up a few feet they straighten up.
Old Mar 19, 2004 | 05:29 PM
98xlt4x4's Avatar
98xlt4x4
Definately sounds like a bad thing... I'm not familiar with the 97 and older front suspensions, but I'm sure someone will have some ideas.
Old Mar 19, 2004 | 05:45 PM
99 ranger bob's Avatar
99 ranger bob
id get under there and look prolly a loose hanger or maybe a bushing in the spring better check it though it sure dont sound too healthy
Old Mar 19, 2004 | 08:38 PM
hreed's Avatar
hreed
It most certainly is not normal. Something is loose in the steering or suspension. Check the tie rod ends, all the clamps and bolts, wheel bearings, and ball joints again. I would suggest not driving it until you find out why it is doing that!
Old Mar 19, 2004 | 08:43 PM
ranger88a's Avatar
ranger88a
Yes they will do this on a 2 wheel drive. Do check out the front end however, but on a 2 wheel when backing they do tend to lean the top of the tire in and sag. I work on them most every day.
Old Mar 19, 2004 | 08:53 PM
hreed's Avatar
hreed
That's a new one on me. Where is the movement of the tires coming from when backing up? Why does it only do it backing up? Thanks for any info on this. I am really confused on this one.
Old Mar 19, 2004 | 09:01 PM
ranger88a's Avatar
ranger88a
It has to do with the twin I beam suspention, when backing up, usually we turn putting pressure on the front I beams. It's hard to imagine, but they sag slightly and the wheels appear at an angle. The moment you go forward they straighten up. I have seen it many many times F250 2 wheels do it also. I've been doing it for 22 years.
Old Mar 20, 2004 | 01:34 PM
Vin 95's Avatar
Vin 95
Thanks Ranger88a,now im not so worried,the only thing I could find under the truck was about 1/8 in. play (front to back)in the radius arm bushings.Do I have to remove the springs to replace these like the book says or can I trick them in by supporting the spindle on a floor jack and sliding it fowards then back?
Old Mar 20, 2004 | 03:10 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Do a search in the Explorer Forum on this. I read about a month ago in there that a guy removed the link on the stabilizer bar end and was able to move the axle/radial arm combo forward enough to do the bushing replacement. Other people had posted their improved methods too.
Old Mar 25, 2004 | 12:30 PM
tommyz's Avatar
tommyz
This is caused by "ackerman". All vehicles have it. It is a measurement from a spot on the front spindles to the center of the rear-end. Where those two line cross, you either have positive, negative, or "0" ackerman. That is what causes you tires to look weird when backing up.
Old Mar 27, 2004 | 01:03 PM
007bronco's Avatar
007bronco
Every IFS ford 4wd I've ever had did this. I would never back into parking spots cause it looked so bad. Big tires and worn ball joints definately exagerate it. Maybe your toe in is too much as well?
007BRONCO
351Cleveland C4
Dec 7, 2014 10:52 PM
TexinCali
Dec 2, 2013 01:47 PM
Risk176
Feb 13, 2012 11:49 PM
JonArmy
Oct 27, 2011 02:36 PM
Unrealo4
Feb 28, 2011 06:50 PM
