thermostat housing
thermostat housing
on my 92 f-150 5.8, i'm having problems with coolant leaking out my thermostat housing. it only leaks until the coolant in the radiator reaches a certain level. when i replaced my thermostat i put a bead of rtv sealant on each side of the gasket and then torqued the bolts down to spec but it is still leaking. is it a problem with the housing or is this a common problem on these engines? i really haven't been worrying about it but its starting to get warmer here and i don't really feel like having my engine overheat if possible. any help would be appreciated.
bill
bill
joey2fords
03-06-2015 01:24 PM
Brown1989
12-27-2014 06:41 PM
maxt
04-08-2005 09:19 AM
