Finding coolant leak 1989 f150 5.0
I have tracked the leak down to the front of the engine behind the Accessory drives. It is not a hose and my water pump is pretty much brand new. I just can't think of anything that could be leaking back there. The thermostat housing looks dry. Is there anything on the passenger front side of the engine that could be leaking.
Thanks
Also, it only leaks if I drive it for a short time and then turn it off without the thermostat opening up. If I let the thermostat open up it doesn't leak. Most of my driving is short distance so there in lies the problem.
Thanks
It isn't coming from intake manifold gasket. I think it might be a freeze plug right behind the alternator but I'm not sure if the 302 has one there
BillC1009
16
08-07-2022 10:16 PM
smashclash
12-06-2012 01:06 AM
