4X4 Chopping tire Question...Again
Old Mar 17, 2004 | 02:31 PM
pbuzz3323's Avatar
pbuzz3323
Learned about the tires chopping alittle during turns with 4 x 4 engaged when starting with wheels turned. Still does it at slow speeds and im concerned, kinda bucks alittle even on very slow accelleration. How can I check this out and what could problem be. 2000 Crew cab Dually 7.3 LB..Thanks
Old Mar 17, 2004 | 02:39 PM
jamesbfishin's Avatar
jamesbfishin
When you experience this prob, are you turning in 4x4 while on dry pavement, that would certainly cause the bucking because of too much traction. It is suggested to not use your 4x4 on dry pavement at all or at least for any distance. Good luck
Old Mar 17, 2004 | 05:44 PM
pbuzz3323's Avatar
pbuzz3323
NO, During snow today...snowy pavement
Old Mar 17, 2004 | 07:16 PM
petes4x4's Avatar
petes4x4
mine does it on real tight turns and going very slow. it has done that since the day i got it
Old Mar 18, 2004 | 12:06 PM
jamesbfishin
I have never experienced that on snow before even in tight turns, I have however had it happen quite often when transitioning from dry pavement to the sandy access roads to get on the beaches by my house. I don't think this is a problem, just the nature of the beast.
Rumhillfarm
Jan 27, 2010 06:38 AM
popuppaul23
1997 - 2003 F150
Aug 17, 2008 10:56 AM
tuffenuff
Jun 29, 2006 01:01 PM
RA81222
1978 - 1996 Big Bronco
Feb 24, 2004 02:05 PM
timucin
Dec 4, 2003 04:12 PM
