header installation
Old Mar 17, 2004 | 11:35 AM
my79f's Avatar
my79f
header installation
do i absolutely have to take off the intake and carb to put my new dynomax headers on. and if i do what should i do about taking off the fuel lines.
Old Mar 17, 2004 | 12:14 PM
desperado_18_2000's Avatar
desperado_18_2000
Since the intake and exhaust manifold use the same gasket, meaning they are attached, you will have to remove the intake to get the lower portion of the gasket off, i'd assume.
To deal with the fuel lines, take them off, and find an appropriate sized bolt that will fit inside the fuel line, make sure it is clean, slip it inside the fuel line, and tighten the clamp over it, effectively trapping all the excess fuel in the line and not allowing it to leak.
With the headers and the new gaskets, these two will be separate deals, and you won't ever have to worry about this issue again.
Old Mar 17, 2004 | 12:55 PM
my79f's Avatar
my79f
also what is a good way to get stuck bolts off. there is one that is not wanting to come off and i dont want to heat it up b/c of all the hoses around it.
Old Mar 17, 2004 | 06:59 PM
dogdaysunrise's Avatar
dogdaysunrise
WD40!!!!
Old Mar 18, 2004 | 09:18 PM
thecowboy's Avatar
thecowboy
spray some wd40 or liquid wrench i like it better spray it all over the bolt and tap around it with a hammer repeat this several times and it will come right out.
let us know how it went.
Old Mar 18, 2004 | 11:42 PM
my79f's Avatar
my79f
thanks thats exactly what i did and it WORKED
Old Mar 18, 2004 | 11:43 PM
my79f's Avatar
my79f
also does anybody run with open headers to the exhaust shop. im just wondering cause tomorrow i get the new exhaust
Old Mar 19, 2004 | 12:29 PM
dogdaysunrise
see wd-40 is amazing
