351 W vs 351 C
Old Mar 16, 2004 | 11:02 PM
Redleg319's Avatar
Redleg319
351 W vs 351 C
What are the differencs between the 351 Cleavland and the 351 Windsor.
What are their best applications.
Also which is/was the most economical and least problem prone, the 351m or the 400.
Old Mar 17, 2004 | 08:04 AM
jwtaylor's Avatar
jwtaylor
The coolant passages are different on the windsor and clevelands. You can install the cleveland heads on the widsor but you must modify the heads slightly, due to the coolant passages.
The cleveland heads in stock form, are a lot better than the windsor. The cleveland weigh more. Either motor would fit any application, except the 4v headed cleveland, it would be best suited for a light car. I know nothing about the modified motors...later
Old Mar 17, 2004 | 01:50 PM
scroob's Avatar
scroob
351W is a do all passenger car/truck engine. 351C is a high revving performance engine.
You would not be happy with a 351C in a truck, since it doesn't have the low end torque you'd want.
They both have the same tranny bolt pattern and will generally interchange without issues.
As far as the 351M/400 question, they are the same engine except for stroke. They are both reliable, and if you have a 351M and like it, you'll like the 400 more. I don''t know any engine you can get more from with less investment. It's a monster just waiting to be unleashed.
http://www.geocities.com/styleline58/400.html
Old Mar 18, 2004 | 09:42 PM
Redleg319's Avatar
Redleg319
My 78 Bronco had a 400, the power was unbelievable.
Had to ask though I heard the 351m was generally the same
Old Mar 19, 2004 | 08:42 AM
daerhldgs2's Avatar
daerhldgs2
the 351M and 400 aren't economy engines, terrible gas mileage , but a good head versus the windsor , larger canted valves, but a huge heavy motor for the displacement, equal in size in fact somewhat larger in some areas than a 460 and they bolt up to the same bellhousings.
Old Mar 19, 2004 | 09:35 PM
rv4alex's Avatar
rv4alex
Red
The 351m/400m Motors were an attempt by ford to make a more enviornmentaly friendly engine, yet produce a good amount of power. To do this they retarded the timing, reduced compression and a couple other things that I cant remember off the top of my head. Needless to say in their stock configuration they failed. If you are looking for performance, the 460 is probably the best bet. I purchased a 400m, and then discovered what I had. It took a new cam, timing gears/chain, intake and 4bbl carb to get a real screamer. It would have been alot cheeper to get a 460.
Old Mar 20, 2004 | 01:00 PM
scroob's Avatar
scroob
Keep in mind that through most of it's run, the 460 was also detuned the same way the 351M/400 was. You'd have to do the same mods on one of them to unleash it's real potential. So, just dropping in a 460 is not necessarily a cure.
For example, the 1977 460 was a 195 HP gas guzzling, smog choked behemoth. You'd have to do a new cam, timing gears, intake and 4V carb on it also to get anything out of it.
Weight: 351M/400 - 575 pounds. 460 - 720 pounds.
Point being, if you already have a 400, you might as well keep it unless you are really into doing the swap.
400s are no more gas guzzlers than any other engine the same displacement. It all depends on the engine's efficiency and application. No engine is going to get good gas mileage in a big truck. The 460 will drink just as much, maybe more.
I have a 400 in my '71 Galaxie, and it gets 17.5 MPG. My '69 Galaxie with the 429 gets 15.5 on it's best day. Both are 2V and bone stock.
Old Mar 20, 2004 | 02:31 PM
RTM's Avatar
RTM
I disagree about the 460 getting the same or worse than a 351M/400. When I owned the 78 and 79 4X4 trucks I had the all got 460 motors in them and my MPG went up and I had much better performance to boot. This could have been due to some tired motors but i saw much better results from the 460 than I ever had gotten from the 351M/400 motors.
Old Mar 21, 2004 | 09:45 AM
daerhldgs2's Avatar
daerhldgs2
I'm not sure where the weight figures came from but my listings tells me that the 351M/400 and 429/460 are within 35# of each other. Another factor might be that the 460 oils better and normally (there are always exceptions) a 460 will last longer .
Old Mar 21, 2004 | 12:53 PM
scroob's Avatar
scroob
The engine weights came from a list on Dave Williams web site, which for some reason is not allowing me access right now.
http://www.bacomatic.org/~dw/engfyi.htm
There is another list circulating around which lists the 429/460 as weighing 640 pounds. This figure was proved to be erroneous after much discussion and debate on the old mailing list. Someone put a freshly yanked 460 on the scale and it weighed 725 pounds.
Old Mar 21, 2004 | 12:55 PM
scroob's Avatar
scroob
RTM, were the 400s stock? Nobody is even suggesting using a stock 400. The motor is a dog unless you unleash it by changing the cam and timing set.
Old Mar 21, 2004 | 06:22 PM
RTM's Avatar
RTM
Yes the 400's where stock. I have seen more 351M motors than I have 400. I had a 400 but gave it to a buddy of mine. Not sure if he ever used it or not.
gettler
46
Dec 16, 2019 02:51 PM
429 merc
21
Jun 30, 2015 06:37 PM
rsalter66
May 28, 2007 01:35 PM
jec27
Oct 20, 2003 08:32 PM
canadianfordman
Jan 22, 2001 12:40 AM
