I want to buy differential covers for my 99 Ford. I see alot of you guys have pictures and the differential covers are nice and shiny - How do I know which ones to buy? Here is the page I was shopping on.
Originally posted by truckman I mean what size do I order - my back one has 12 bolts - is that all I need to know to order? I think its the stock differential gears.
You have a 10.5 inch sterling or visteon rear. (Company changed name so i've seen it called both)
For the front you have a dana 50 but you probably won't be able to find a cover for that since most people list a dana 50 as the ttb 50 that's under the older F250's. You should just order a cover for a front dana 60. It is the same thing outside. Only the internals are different.
The 50 and 60 are identical in all respects from the outside as far as I know. Also he says his has 12 bolts and only 50's came in 99's which is what he has.
Originally posted by RRMike The 50 and 60 are identical in all respects from the outside as far as I know. Also he says his has 12 bolts and only 50's came in 99's which is what he has.
beware of the polished alum covers, igot some a couple of years ago from above mentioned place.
after time i noticed grease/dust build ups on the out sides, keep looking for some type of leak on my truck.
seems that the cast for the covers were to porious, and seep !
might be why they were at a discounted price, it took to long to determin the cause/or prove it.
Originally posted by brad diesel beware of the polished alum covers, igot some a couple of years ago from above mentioned place.
