74 ford vibration
Old Mar 16, 2004 | 08:24 PM
walt wolford's Avatar
walt wolford
74 ford vibration
I have a mild vibration at around 2800-2900 rpm this is even in neutral or with the clutch depressed. I have a 74 f-100 with a 390 and an np-435 trans and np-203 transfer case. would like to see if anyone has any ideas
Old Mar 16, 2004 | 08:39 PM
youngblue's Avatar
youngblue
Is this while driving down the road? If so, could be the driveline. or related; carrier bearing bad, U-joint bad etc.
Old Mar 16, 2004 | 08:46 PM
walt wolford
no this problem occures while sitting still but you can still notice it running down the road
Old Mar 16, 2004 | 08:54 PM
youngblue's Avatar
youngblue
I am alittle stumped.... got good engine mounts?
Old Mar 16, 2004 | 08:57 PM
walt wolford
that was my next look i did crawl under tonight and seen that the trans transfer case mount is spliting not sure if that has anything to do with it
Clifford74
Offroad & 4x4
May 8, 2014 01:26 PM
Clifford74
Apr 6, 2014 01:54 AM
74crwcb429hibPS4spd
17
Oct 18, 2004 05:10 PM
elliott
Sep 16, 2002 04:49 AM
