Sponsored by: Real Truck
Stiff Steering
Old Mar 18, 2004 | 06:48 PM
FortyFords's Avatar
FortyFords
Okay ,what size and brand snow plow are you running?
Improper installation on balljoints can increase the failure rate.
You shouldn't have anything bigger than a 8" plow on a 250 .
Do you have the plow pkg on this truck ?
You have a diesel ,its heaveyin the front without the plow . Don't be like alot guys I see running around with their plow on when its not needed .
Get some "moog" greaseable ball joints.
If you run oversize tires and wheels this will also put some stress in the ball joint area.
Just my .02
Rich
Old Mar 18, 2004 | 11:04 PM
Raf20's Avatar
Raf20
I have a Fisher 8' plow and yes I have the plow package. Does the plow package include more heavy duty ball joints?
Believe me, I never drive around with my plow unless I have to plow.
The tires are OEM size.
I now realize how much more weight the diesel motor has over the gas motor. But shouldn't Ford adjust for this in their front ends if this is the case?
The dealer is already in process of replacing the ball joints with OEM parts, it's too late to change to your suggestion. What I don't understand is why Ford still makes these joints non-greasable when the customer would be much better off with the greasable joints???
Raf
Old Mar 19, 2004 | 04:43 PM
Raf20's Avatar
Raf20
Well I just got my truck back from the dealer, new upper and lower ball joints and new steering pump. Problem is I can't tell if it is actually fixed. The front end definitely feels much firmer and tighter which is great.
The thing is I still feel somewhat the same steering "stiffness" as before. Basically, this is what I am experiencing:
With the transmission in Park or Drive (and at a stand still), if I fully depress the brake pedal, I can't turn my sterring wheel. If I let off the brake pedal to about half way or less, I can turn the steering wheel. The service manager said that this is normal as both the steering and brakes run off the same "lines" (sorry, I'm paraphrasing here).
Is this what everyone here experiences? Could you folks try this on your own trucks so that I don't lose my marbles to paranoia.
I would truly appreciate your feedbacks on this.
Raf
Old Mar 19, 2004 | 08:05 PM
99f350sd's Avatar
99f350sd
I have heard of that......Get your old pump back if it didn't fix the problem....I hate parts changers!!!
Snowseeker
37
May 31, 2017 04:48 PM
landscapeguy
Aug 6, 2016 07:14 AM
Fernie_Wan_Kenobi
Modular V8 (4.6L, 5.4L)
May 29, 2016 02:33 AM
Jdot443
Oct 27, 2015 10:21 PM
Johnnyfiveoh
Dec 3, 2002 11:32 AM
