Transmission temperature question(s)
Old Mar 16, 2004 | 10:45 AM
myotis's Avatar
myotis
My truck (250 V10) did not come with a towing package and I am planning to get a transmission cooler installed in preparation for twoing a 5th-wheel. Is a bigger tranny cooler better or can the fluid be too cool? Also, should I install a temperature gauge and if yes anny recommendations? Can I do this myself or do I have the transmission shop do the job?
Thanks
Old Mar 16, 2004 | 11:51 AM
shorebird's Avatar
shorebird
Any time that you are going to add cooling capacity it is best to go with "worst case" needs. Get the large area cooler. As to the temp guage it is a relatively easy install. A pillar pod is a good mount for the guage. The sensor is usually no problem for the average driveway mechanic. My gallery has this mod in it.
Old Mar 16, 2004 | 12:59 PM
BLK94F150's Avatar
BLK94F150
I can't believe that a 250 doesn't come standard with a "towing package". It is a work truck. Even if it says lariet on the side.
Mike
pilot47
Oct 31, 2016 01:55 PM
Jeff53
Aug 7, 2016 09:25 PM
northwindone
Jun 23, 2016 08:30 AM
Edmund
Mar 14, 2006 08:12 PM
fatboy*61
18
Jun 5, 2005 10:02 AM
