Sponsored by: Real Truck
Headlight adjust
Old Mar 15, 2004 | 08:21 PM
desertford's Avatar
desertford
Headlight adjust
I think I need to adjust my headlights after my lift im constantly getting flashed by oncoming cars. Manual doesnt say just to take to authorized technician. can anybody walk me through it
Old Mar 16, 2004 | 05:40 AM
slc10844's Avatar
slc10844
In order to properly adjust the headlight you need a headlight machine. In Maryland, vehicle inspection stations are required to have an approved machine to perform inspections. I don't know if CA has an inspection program or not, but if you do, there is a place to start. Dealer would be a second choice. I would think a headlight machine would be "required equipment" for them.
Old Mar 16, 2004 | 10:29 AM
Yeti's Avatar
Yeti
If I remeber right, there are only two phillips like adjustments, one for up and down and one for side to side.
Old Mar 16, 2004 | 01:51 PM
Loyd Lucas's Avatar
Loyd Lucas
Just take it to a lamp station, it's not that expensive.
Old Mar 16, 2004 | 02:47 PM
V-104Me's Avatar
V-104Me
The adjusting screws are 'Torx'. Not sure on the torx spelling. Dealer gets about 85 dollars to adjust.
Old Mar 16, 2004 | 03:03 PM
stepman's Avatar
stepman
Like Yeti said, you have an adjustment for up and down and one for side to side. Not sure how yours is actually set up but most of them anymore are done remotely of the light. ( a cable runs to where you can get to it as opposed to right on the front of the light) They work the same as the old style though. One will run to the side and one to the top of the light (or bottom) If it was mine, I would put it in the street and adjust them down a little. It's a little easier to do it when it is sitting in the street so you can see where they are pointed. ( of course this would have to be done at night, preferably on a "quiet" street)
This is a comprimise thing. Adjust them low enough that you don't get flashed anymore but, keep them up enough to see where you are going.
Old Mar 16, 2004 | 03:04 PM
Six Liter Fan's Avatar
Six Liter Fan
They are a Torx adjustment. Looking at the headlight there is an inboard and outboard adjuster. The inner one is for height adjustment. Very easy to do. A little turn goes a long way!
Old Mar 16, 2004 | 08:10 PM
desertford's Avatar
desertford
Thanks guys will adjust tonight
Old Mar 16, 2004 | 10:24 PM
fireman28's Avatar
fireman28
A T-20 works on the adjusters. Park your truck about 6 feet from a white wall of garage door and adjust untill they are even and aiming straight. Then back the truck up about 10 feet and fine tune. Hope you get this in time to help.
