Bendix Box Options
Have a 1968 F-100 that came stock with P/S (Bendix Design). The steering gear started leaking so I pulled and sent to be repaired which was subsequently lost in shipment, USPS with no insurance "found box with no parts in Atlanta". Now I have read through some post and think I have a understanding of my options but would like to get confirmation.
1.) Pay some real $$ to replace the Bendix without a core $545.00 best so far "still won't be able to get seal parts for it and the Bendix is known to have leak problems".
2.) Drop in a manual gear and it will fit up to the existing column "sure like the P/S though"
3.) Replace with the Ford design and replace or shorten? the column with one that was supplied with the Ford Design. "I could use some help with this option"
Questions for option 3
A.) How much do I need to shorten, I am assuming the length would need to come from the gear coupling side. It looks like the coupling hub is heat shrunk on which would require machining to get a new fit?
B.) Can I keep the column shell, shift tube, etc. and just get a shorter shaft?
C.) What years, Models, etc could I look at for a new column"
Thanks in advance.
No Truck in Texas (unacceptable)
Thanks for the reply. I forgot to mention I had a automatic. I found a column in a yard "do not think it was stock" it had a floor shift with no slots for the shift lever (ford make a floor shift?)
Regards
68rdr
I'd just find a '69-'72 pickup in a boneyard and get the column, steering box and firewall bracket...and bolt 'em in. They're actually fairly plentiful. The '73-'79 columns will work, but as mentioned above a little rewiring will be necessary to accomodate the column-mounted flasher switch, since the older trucks either had them in the glovebox or on the dash.
