lifter preload help
Old Mar 15, 2004 | 05:40 PM
tastyklair's Avatar
tastyklair
lifter preload help
I'm trying to get my lifter preload set and it is either right on the outer max (.060) without shims or right at the minimum with the shims (.020). Is it better to have it at the high side or the low side?
Old Mar 15, 2004 | 06:34 PM
X-1's Avatar
X-1
With out the shims you are opening the valves more, this puts them nearer to the pistons, as long as you are not having a piston and valve hitting each other than you are okay, putting in the shims will cause the opposite, and you will have less lift on the valves, either way as long as it is in specs, and no parts hitting you are good to go.
1972-34ton
Mar 18, 2012 11:29 PM
eatfish
Apr 23, 2010 09:13 PM
FordTrucksKickGM
Feb 17, 2008 11:49 PM
frankalonge
18
Mar 13, 2007 02:28 PM
MustangGT221
Apr 20, 2002 04:04 PM
