ford no spark
Old Mar 15, 2004 | 04:25 PM
JSPULLER's Avatar
JSPULLER
ford no spark
Hey all. Ihave a problem w/my 87 Ford truck with a straight 6 in it. No spark I have replaced everything related, and still nothing. Also there is no power to the fuel pump at the same time of not having any spark. Can anyone help me figure this out.
Old Mar 15, 2004 | 04:37 PM
drewcoolness99's Avatar
drewcoolness99
is there power to the coil? theres probably a frayed wire somewhere. All you need is a volt meter/test light and keep poking down the line to find the problem.
Old Mar 15, 2004 | 04:46 PM
JSPULLER's Avatar
JSPULLER
Yes, there is 11.62 volts to the coil. The moduale, pickup coil and coil have all been tested and replaced. I appreicate the reply if you have any othe ideas let me know...
Old Mar 15, 2004 | 06:36 PM
christ's Avatar
christ
Fuel Pump relay ? Have you tried to pull the codes?
Old Mar 15, 2004 | 06:38 PM
JSPULLER's Avatar
JSPULLER
pull codes?? from where
Old Mar 15, 2004 | 06:45 PM
christ's Avatar
christ
Info on pulling diagnostic codes:
https://www.ford-trucks.com/forums/s...hreadid=112293
I would also suggest doing a search of this site for "no spark" or "no start"...lots of stuff should pull up.
Are you sure that the fuel pumps aren't running...they should only run for two seconds or so after turning on the key.
Old Mar 15, 2004 | 06:59 PM
JSPULLER's Avatar
JSPULLER
You might be right about the pump but I checked w/key on and did not register any power. That still does not explain no spark.
I thought there might be a relay or something that connects the two, to create a circuit. Which I am told it should have been the moduale. I do not have a code tester. But I haven't tried the key turn 3 times to see if something came up that way. You are about the only helping in a way. thanks I can use more info. if you have anymore
Old Mar 15, 2004 | 07:17 PM
christ's Avatar
christ
First , you need to be more patient...its only been a few hours since you first posted this problem, and it really wasn't necessary to create 2 seperate threads.
Second, if you read thru some of the old posts you'll find that a no-start condition is a rather common ailment here...should get some good ideas on what to look for .......
Turning the key 3 times won't do a thing, and you don't need a code reader to pull codes....follow the link I provided...it details how to pull codes...
Old Jun 5, 2004 | 07:48 PM
frustrated ford guy's Avatar
frustrated ford guy
i have replaced EVERYTHING on mine and have power to the coil and and module but nothing from the coil. New pickup with new distrib. EVERYTHING! What was it with yours?
Old Jun 6, 2004 | 08:34 AM
LoosMaster's Avatar
LoosMaster
Under the dash, drivers side, just to left on the firewall there should be a little black box with a red button on top, see if it's tripped and reset it. This is the fuel pump inertia switch. I think it cuts the ignition also.
Old Jun 6, 2004 | 10:54 AM
JSPULLER's Avatar
JSPULLER
Heres What I Found Guys. #1 It Took 3 Modules Before I Got A Good One. Dont Buy Any Electrical Parts From Autozone. One Lesson Learned The Hard Way.
#2 Before I Got A Good Module I Found I Had A Bad Map Censor, Which I Found Through Computer And Electical Diagrams Where It Was Linked To The Computer.
#3 Pulled Computer And Found A Small Burn Or Short In The Circuit Board.
Old Jun 6, 2004 | 11:12 AM
JSPULLER's Avatar
JSPULLER
So, It Still Didn't Work W/new Computer And Map Censor. That When I Put My Old Module In And I Got Spark And Power Everywhere But The Timing Was Still Off Because The Module Was Still Malfuctioning, Thats With The Old One. Put New One In, Badddd. No Spark. Thrid One Was A Charm... Let Me Know If Y'all Need Details
Old Oct 26, 2004 | 02:39 PM
Tectron1's Avatar
Tectron1
Did you happen to have the parts store test your module? Did they say it was good, even though it was bad. how about the new ones that were bad?, did their machine say they were bad? Ive had some experiance in the past with hei modules that their machine said were good that were actually bad. Id rather not relive that again
Old Oct 27, 2004 | 08:15 AM
low-side's Avatar
low-side
Cold tests on modules and coils are worthless - I took a look at the guide while the guy testing a module for me was looking for a lead and it had accuracy ratings for individual modules listed. They ranged from 37% to 54%. Electrical components expand when they heat up and connections can be broken during the expansion. That's why you get the old scenario where a car starts fine when it's cold and then dies when it warms up. As far as all of that stuff burned up on your truck - did anyone ever weld on it w/o ramoving the comp. or remove a cable while the engine was running? A burn inside an ECM is pretty unusual. Glad it's running now though.
Flatbed Ed
6.2L V8
Feb 24, 2016 07:51 PM
zech
1983 - 2012 Ranger & B-Series
Sep 18, 2015 09:25 AM
5speed50
2009 - 2014 F150
Jun 1, 2015 03:08 PM
Boodrow379
Jul 10, 2013 09:41 PM
mikecrom83
Jun 3, 2013 03:50 PM
