problem with undercoating
Old Mar 15, 2004 | 12:57 AM
stangboy_82's Avatar
stangboy_82
ok so I"m an idiot I coated the floor of my truck with 3m undercoating. I knew it wouldn't dry hard and that's what I wanted but I din't realize that it doesn't really dry at all it's just sticky and makes a mess of everything. so lesson learned I screwed up now I need to fix it. does anyone know how to remove this stuff should I just use a scraper to get the most of it off and then use paint thinner to get the rest up? or is there something else I should do instead?
I want to be able to put a bedliner down after this any suggestions for one that will have a little spring to it instead of being really hard?
thx in advance for any help
Old Mar 15, 2004 | 02:56 AM
Aekisu's Avatar
Aekisu
<cr>
Putty knife, lacquer thinner, and paper towels are what I use. Use lacquer thinner with care. It's almost as flammable as gasoline and can damage some paints.
Old Mar 15, 2004 | 02:17 PM
stangboy_82
thanks a bunch aekisu
Old Mar 22, 2004 | 07:24 PM
stanz's Avatar
stanz
3M makes a drill mounted 4-5 in. plastic composit wheel. I bet that would do a good job getting the bulk of it off real fast. You should be able to find one at your local hardware store or Wal Mart.
Good luck.
Old Mar 23, 2004 | 03:05 AM
stangboy_82
I kinda doubt that would work stanz it's a real tar like stuff and if it's one of the wheels I'm thinking of then I'm pretty sure that would just make a mess of the inside of my truck. thx though and if I"m just being confused on this then please let me know
Old Mar 23, 2004 | 07:25 PM
marc9000's Avatar
marc9000
I would try the lacquer thinner first. If it seems too strong, try a strong clean-up wash, like PPG's DX-440. (DX-330 would be too weak) Once most of it is off, red scotch brite pads, soaked in the solvent, would probably do the final clean up.
SVTDriver97
13
Dec 17, 2014 02:03 AM
78bigbronco
Aug 26, 2009 10:17 PM
78250crewcab4x4
Paint & Bodywork
May 30, 2007 10:40 PM
78ford351m
18
Apr 13, 2006 04:48 AM
Curtis360
Paint & Bodywork
Mar 18, 2003 09:20 AM
