Exhaust Leak
Old Mar 14, 2004 | 10:13 PM
Mr Dave73's Avatar
Mr Dave73
Exhaust Leak
My '97 has a slight exhaust leak that I cannot find. It is somewhere on the drivers side under the hood. I have loosened and retightened the collector bolts at the exhaust/manifold flange and it does not appear to be leaking there. I cannot see any telltale signs of a leak around the manifold/head flange or anywhere on the manifold itself. Any ideas on how to track this down?
Old Mar 14, 2004 | 10:16 PM
Mr Dave73's Avatar
Mr Dave73
Its a 97 Mountaineer, V8 AWD.
Old Mar 14, 2004 | 10:30 PM
ckrichard's Avatar
ckrichard
What is leading you to believe that there is an exhaust leak?
Chris
Old Mar 14, 2004 | 10:37 PM
Mr Dave73's Avatar
Mr Dave73
My ears
Old Mar 14, 2004 | 10:48 PM
ckrichard's Avatar
ckrichard
If you can get ahold of a mechanics stethascope that would make it real easy to fine. I'm not sure about this but you might be able to make one from a piece of small diameter plastic tubing. Just hold one end next to your ear and move the other end along the exhaust system till you hear the leak through the tubing.
Chris
Old Mar 14, 2004 | 10:55 PM
Mr Dave73's Avatar
Mr Dave73
I used to have a horn off of an old trumpet that I used just for that purpose. Wish I still had it....
Old Mar 15, 2004 | 07:17 PM
Mr Dave73's Avatar
Mr Dave73
anybody else?
Old Mar 16, 2004 | 07:46 AM
78fordman's Avatar
78fordman
is it loud or just ticking. If it is just ticking probably the exhaust manifold gaskets.
Old Mar 16, 2004 | 08:53 AM
rb26powered's Avatar
rb26powered
I had the same problem with my 97 Explorer V8 AWD. As I was torqueing down the manifold bolts, I found that 2 were loose and 1 was missing. Replaced the lost one and the leak was fixed. I encountered loose manifold bolts on the right side as well and torqued them down.
Old Mar 16, 2004 | 12:32 PM
golfboy17's Avatar
golfboy17
Yup its your manifold bolts or it the pipe that bolts into it which you can see in the wheel well, those bolts need to be torqued, i had a problem with mine, they would keep comming lose could not find it took it to my mechanic found it right away, first few times he did not torque it last time he removed the bolts cleaned the threads torqued them now its nice and quite, he did it for free for me
Corpsman24
26
May 30, 2023 03:06 PM
Owl
Feb 11, 2015 01:58 PM
96f150
1997 - 2003 F150
Mar 28, 2014 05:27 PM
happyhondarider
30
Aug 5, 2012 02:48 AM
Tomm
1983 - 2012 Ranger & B-Series
Jan 28, 2010 04:04 PM
