Sponsored by: Auxito
exhaust manifold fitting
Old Mar 26, 2014 | 08:45 PM
96f150's Avatar
96f150
....After doing my intake, I did get rid of the coolant issue, but now it sounds like I have an exhaust leak coming from the drivers side. All exhaust manifold bolts are there..no leakage at the manifold. I "think" it may be coming from the egr tube where it goes into the ex manifold.....anybody have any luck getting that nut to loosen down on the manifold? The EGR side loosened up real easy...I just moved it away from the EGR when doing the intake.....I think I may have cracked it down on the flange.......
Old Mar 27, 2014 | 07:00 PM
96f150's Avatar
96f150
So I searched around a bit and found one of the hoses on the bottom of the DPFE sensor had cracked! So they dont have any slack in them, so I unbolted the sensor and tie wrapped it closer!! No more exhaust noise or smell!! But I took the truck for a ride and it started idleing rough, so I shut it off when I got to my appt, then I came out 30 minutes later.crank crank crank, had to hit the pedal to get it started!!, I drove home the 2 miles and checked codes.....had a pending P1405, I checked the hoses....all is good...does the sensor have to be mounted upright??
Old Mar 28, 2014 | 05:27 PM
MJE426's Avatar
MJE426
Get the right hoses and replace the DPFE. The wrong hoses can burn thru very quickly.
TX92F150
32
Feb 23, 2014 07:16 PM
john165
Apr 29, 2012 04:29 PM
jerryga
Jan 6, 2009 09:53 PM
danbov
Apr 3, 2007 09:20 AM
allford86
Nov 15, 2004 08:54 PM
