95 explorer wiring
Old Mar 15, 2004 | 06:50 PM
mrblankenship's Avatar
mrblankenship
95 explorer wiring
I am having a problem with installing an aftermarket deck in my explorer. Just bought the truck so i figured that this operation would only take me a couple hours but it has been kicking my ***. I bought aftermarket wiring harness to plug into the stock harnesses and the harness with the power, ground, memory etc work well. The deck turns on no problem and works with an external speaker(the deck is not the problem). But with the harness with the speaker wire in it is hooked up there is no sound. Does any one know why there is another ground wire on this harness? The only other thing i can think is that because there are rear audio controls mabey this is my problem?? Someone please help
Old Mar 15, 2004 | 06:53 PM
christaylor's Avatar
christaylor
Blue wire needs a power source for the factory amp. Hook it up to the power antenna lead if no other is available.
Chris
Old Mar 15, 2004 | 08:14 PM
prcrboy's Avatar
prcrboy
If you plan on using the factory amp, you must use an adapter. otherwise it must be bypassed.
Old Mar 15, 2004 | 08:19 PM
christaylor
I have had two explorers and both worked fine as long as the blue wire was hoked up.
chris
Old Mar 15, 2004 | 08:47 PM
mrblankenship
this truck only had casette am/fm not premium sound--would there still be a factory amp? Which blue wire--light blue, dark blue, blue w/ black strip?
Old Mar 16, 2004 | 06:21 AM
christaylor
Its been a few years but it was a dark blue wire no stripe. I think all of them had a factory amp. When I hooked up the first one on my former 91 I spent 3 hours trying to figure it out then took it to Circuit City and asked them what I could be doing wrong and they showed me the amp(blue) wire. My 95 was the same.
Chris
Edit If you search the Audio Forum you will find this discussed many times. ct
Old Mar 16, 2004 | 01:24 PM
mrblankenship
thanks hooked up blue wire--did the trick
i owe u
