Hey all! On the driver side door the screw has broken off where the handel from the window crank is supposed to go in. So I have no way of attaching the handel back on. Whats an easy fix for this with out replacing the whole unit. Please help. Thanks....
Get a screw out set. It looks like a drill bits but they are reverse drill. Typical drill bits when turned clockwise they dig deeper and when turned counter-clockwise they pull out.
This screw out set is the opposite. When turned counter-clockwise they dig deeper (that's the secret of removing broken bolts because they dig deeper as you turn counter-clockwise to loosen the stuck bolt). When turned clockwise then the drill bit just pull out.
easy out,
You will have to drill a small hole in the screw first, then use the easy out to remove, chances are with age you might just have to drill it and retap it.
