hard shift
Old Mar 17, 2004 | 10:02 PM
Talyn's Avatar
Talyn
yes. has to have fluid to work. i'm sure there is a refil someplace.
Old Mar 17, 2004 | 10:14 PM
351ballsofford's Avatar
351ballsofford
thanks supercab for all the appreciated help. I'll get this changed and give a post on what happens. thanks everyone else also. Talyn they definetly are so lazy b$#@rds. i'll take it in and see what's up. I'm scared i'm gonna have a load of bad codes.
Old Mar 18, 2004 | 05:23 AM
Supercab's Avatar
Supercab
Cool
On the draining: There is a rubber plug in the bottom of the bellhousing that gives you access to the drain plug in the converter itself, you will have to rotate the engine around until the plug comes into view or feel.
You don't need to worry about filling the converter with fluid, the pump will do it after you put in the first 6 quarts of fluid then start engine and run for about 15 seconds, then shut off and add the balance of the 14 quarts.
This Mercon V fluid costs a little more than standard Mercon/Dextron fluid but for these tempermental transmissions its well worth it.
I wish you guys great luck, and if you have any problems or concerns during the process please don't hesitate to ask.
Old Apr 28, 2004 | 08:06 PM
wrenched's Avatar
wrenched
Sorry for getting in to this late, but I'm starting to have problems with my tranny too. Apparently there are different trannys mated to 94's.
(Supercab)
I'm sure thats what is in the '94 as mine is a '94
My '94 F150 2WD I-6 has the E4OD. See:
https://www.ford-trucks.com/articles/2003/1.php
Also, from Mark Kovalsky's article:
Changing ATF Fluid in a E4OD and 4R100 Transmission
https://www.ford-trucks.com/articles...hangingatf.php
The E4OD and 4R100 transmission system holds almost 18 quarts of ATF, and you must waste a couple of quarts to be sure you get it all purged and replaced, so buy 20 quarts of MERCON ATF [do NOT buy MERCON V!]. Ford also warns against using a fluid that has a dual MERCON and MERCON V rating. You may use either conventional or synthetic, as long as it meets the above requirements.
...The 4R70W uses MERCON V, and the MERCON V can be used on older 4R70W transmissions that were factory filled with MERCON.
Fuelinjector06
Aug 10, 2004 11:05 PM
Fuelinjector06
Aug 9, 2004 09:33 PM
Fuelinjector06
Aug 4, 2004 07:23 PM
Fuelinjector06
Engine Swaps
Mar 19, 2004 08:41 AM
Fuelinjector06
21
Mar 9, 2004 05:35 PM
