Sticky Power door lock
Mar 13, 2004 | 08:05 PM
Passenger side rear power door lock seems to "stick" occasionally when actuated. Any ideas?
99 EB
Mar 13, 2004 | 09:20 PM
I would take the door panel off, and lubricate the latch and lock assembly in the passenger door. I would be willing to bet there is dirt or gunk in there thats making it bind.
Mar 13, 2004 | 09:23 PM
Is there any on-line resource which could show me the steps involved in taking the panel off?
Mar 14, 2004 | 12:22 AM
Sounds like a worn actuator.
Door panel removal:
1. Remove the window regulator switch plate.
2. Disconnect the electrical connector.
3. Remove the rear door handle trim cover.
4. Remove the rear inside door handle.
Remove the door handle bolt.
5. Remove the rear door trim panel screws at the bottom of the panel.
6. Do not pull directly outward. Lift upward and then outward to remove the rear door trim panel.
Mar 14, 2004 | 05:03 AM
thanks.....doesn't seem too difficult.
Mar 14, 2004 | 05:55 AM
I have the same problem, except mine is the drivers side rear.
Is this a defect in lock actuators? Or is this just a couple odd coinsidences?
Mar 14, 2004 | 08:01 AM
I think after "X" amount of cycles, things begin to slow or fai.
Mar 14, 2004 | 10:23 AM
I just had to replace two of them @ 65K miles. They're relatively inexpensive...something like $35 each. I've never had one fail on any other vehicles.
Mar 14, 2004 | 01:14 PM
23 bucks at fordparts.com. If I get reasonably comfortable enough to take the panel off, then I'll go ahead and swap the acutator.
Mar 20, 2004 | 07:55 AM
on my 98' the pass. rear sticks too
Mar 21, 2004 | 07:43 AM
I replace a LOT of lock actuators. Ive had vehicles come in with all 4 bad.
Turbo Dog
2015 - 2020 F150
Oct 14, 2016 03:43 PM
Crewcabber
Oct 15, 2015 12:15 PM
Crewcabber
Mar 31, 2015 06:18 PM
jimandnena
Aug 10, 2014 09:46 AM
gjnicholas
1978 - 1996 Big Bronco
May 7, 2010 08:53 PM
