1993f-150
Old Mar 13, 2004 | 05:38 PM
1970Custom's Avatar
1970Custom
1993f-150
What's best way to increase the performance of an injected 5.0??? I need the modificatins to be as cheap as possable. Any help is apprecieated...
Old Mar 13, 2004 | 07:32 PM
jwtaylor's Avatar
jwtaylor
Headers or electric fans would make a difference, you could bump the timing some. later
Old Mar 16, 2004 | 10:17 PM
fordeverpower's Avatar
fordeverpower
ditch the air silencer, bump timing up, lose mufflers and cats but keep o2 sensors. Other than that headers, underdrive pulleys, electric fan. After that it starts to cost
Old Mar 18, 2004 | 06:30 PM
Ford427Strokr's Avatar
Ford427Strokr
The cheapest thing I've done is put a set of 351 windsor heads on my 92.
Old Mar 18, 2004 | 10:52 PM
MustangGT221's Avatar
MustangGT221
I wouldn't bother with the pulleys...and don't take off your cats it's illegal and won't gain much unless their plugged. If they're plugged, you buy a 60 dollar high-flowing performance cat. Headers and full exhaust is a good option, MSD 6a ignitions are nice too. Big power is available with better heads.
Old Mar 19, 2004 | 02:15 AM
94F150-408's Avatar
94F150-408
fordeverpower...you said to ditch the air silencer? is that the smog "can" on the passenger side fender that goes to the pump? Does removing this make any difference? If this is what you are referring to, would removing it let dirt get in your engine?
Old Mar 20, 2004 | 01:24 AM
fordeverpower
on some vehicles the air tube runs to a fender or up to the hood and is quite restrictive. If you take it off up to the box you get more air to the filter. And the filter still gets all the dirt.
Old Mar 20, 2004 | 05:56 AM
2020's Avatar
2020
I put the March Power&Amp pulleys on botn of my GenI Lightnings and they make a noticeable difference.I'd advise them for a low cost mod any day.I haven't had the first charging problem.
Old Mar 21, 2004 | 01:26 AM
94F150-408's Avatar
94F150-408
OK, Now I know what you were talking about! That probably would get more air into the box, your right! I dont know if there would be any gain though, given the air it would pull in would be hot air from the engine compartment. Here's another idea on that line... install the "inlet" from a 460 motor, this goes to the large opening alongside the radiator and is a much larger tube than the ones on the small blocks. It fits right into the air filter box, I put a picture of a 460 inlet in my garrery for my 94 truck if you want to see one. 5 bones at the junk yard!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
