1997 E-350 no dash lights
Old Mar 13, 2004 | 11:12 AM
taxidriver's Avatar
taxidriver
Unhappy 1997 E-350 no dash lights
This van has 210,000 miles on it. The dash lights went out about 2 years ago. ( i'm finally getting aroungd to fixing them) Also the light that illuminates the temp control went out about a month ago.
I checked the fuses and installed a new headlight switch but they still do not work.
about every few months the dash lights will come on mysteriously but then go out again after a few minutes.
anyone have any ideas? Thanks
Old Mar 13, 2004 | 02:19 PM
Mil1ion's Avatar
Mil1ion
Remove the cluster & Clean the printed circuit and bulb connections.
Old Mar 13, 2004 | 06:52 PM
Ol' Blue 85's Avatar
Ol' Blue 85
I, too, am having this problem and was wondering how to disconnect the speedometer control cable. Everything else is ready to go but I don't want to screw this up. Anyone?
Old Mar 13, 2004 | 08:06 PM
Mil1ion's Avatar
Mil1ion
I don't know about the speedo cable on this one but there is a *squeeze the plastic collar and pull out* from speedo.
Old Mar 14, 2004 | 12:15 AM
taxidriver's Avatar
taxidriver
thanks i'll give that a try.
Old Mar 14, 2004 | 01:27 PM
Ol' Blue 85
I have cleaned all the connections, tested every bulb, replaced the headlight switch, replaced all the fuses, and still no dash lights. I am not trying to steal this thread but I am stumped. All of the other lights work except the ones in the actual instrument cluster. I hope you are having better luck taxidriver. Any suggestions will help.
Old Mar 14, 2004 | 02:03 PM
Mil1ion's Avatar
Mil1ion
Do you have power to the *connector* that goes to the cluster?
Old Mar 14, 2004 | 02:33 PM
Ol' Blue 85
Are you talking about the gray connector that plugs in to the cluster? If so, I think it has power because all of the other lights work when I plug it in. i.e. turn signal indicators, 4x4 indicator, etc. Is there any other connector I should be checking?
