...hot flashes!!
Old Mar 13, 2004 | 02:11 AM
greasymonkey's Avatar
greasymonkey
...hot flashes!!
..I don't know what it is,but my dearest -one seems to been running hot/cold at random!!I do all sorts of things__drive her nasty,drive her mild.Usually she worrrks real good........sometimes seems like she's having a meltdown!!!---no correlation to how I drive her!!...........any ideas??....thanks!!!
Old Mar 13, 2004 | 04:26 AM
XB_Aust's Avatar
XB_Aust
Thermostat?
Check the earth on ya temp gauge?
Alloy heads tend to run the engine a bit cooler, don't ask me why though. Bit of overkill for a temp. fluctuation problem though.
Flush the radiator and consider removing the thermostat alltogether. Just a suggestion, not recommended.
Come on people, someone's gotta hav had this problem b4. Throw in some ideas!
Old Mar 13, 2004 | 09:25 AM
jim henderson's Avatar
jim henderson
Usually a bad thermostat. Sometimes bad electrical connections on the gauges.
If you have an electric fan maybe it is going bad and not cooling when you are stuck in traffic.
Also might be a soft hose. Sometimes under cruise RPM the hoses will collapse which of course cuts off the flow of water. When you stop to check the problem, the suctions goes down, the hose goes back to normal and the temperature drops and you don't find the problem. The way to check for this is first squeeze your large radiator hoses to see if they are too squishy. Most radiator hoses are either stiff or have a spring inside to keep them stiff. Old hoses get soft or the spring rusts away. Another way to check is to have your engine up to temperature and they pop the hood and rev the engine to cruise rpm while watching the hoses. If this is your problem you will see the hose collapse.
Naturally don't stick your hands down there while the engine is runnig, doh!
Good Luck,
Jim Henderson
Old Mar 13, 2004 | 01:39 PM
scroob's Avatar
scroob
She's not going through menopause, is she?
First thing is always to replace the thermostat. Also, verify that the engine realy is hot when the gauge says it is. It's not hard to tell.
Old Mar 14, 2004 | 11:29 AM
greasymonkey
OH YEAH!!--when I mean melt-down....I mean really hot!!!......... ...I've tried blowin 'er hoses.....and all seem clear!---she's a sporty lean 'n mean '57--can't even FIND a thermostat!!!--Love-er dearly --wanna sort er out soon an get some more miles from 'er!!!................SCROOB.......I'll look look in the factory manual on that 'menopause' thing--haven't heard of that!.....................tanks!
RSCHAP1
13
May 5, 2013 05:11 AM
mjunk1
27
Feb 17, 2013 10:12 PM
4inchlovin
37
Jul 8, 2008 11:19 PM
Dustin_86
32
Sep 23, 2006 09:31 PM
mbnv992
21
Mar 28, 2005 11:03 AM
