Tranny ID question
Old Mar 12, 2004 | 11:41 PM
Wingnutt's Avatar
Wingnutt
Tranny ID question
OK way back when I posted a question about the tranny for mt '80 F-250 4wd with a 300 six and four speed. Well I pulled it tonight and low and behold it ain't what I thought it was. It appears to have an aluminum top and what looks to be a pin holding the shifter in place. The tranny I bought came from an 82 F-250 4wd that had a 302 in it that has the screw on cap that holds the shifter in place. They were supposed to be the same trannys (np 435).
Since I already have the replacement tranny sitting on the floor, I am considering throwing it in, but it's about 1 1/2 inches longer. I have plenty of room left in the slip yoke, but am wondering what I will have to do to the cross member to make it fit. I am considering removing the two braces that run to the top frame rail and just redrilling the mounting holes, will this work? Any other suggestions? TIA
Old Mar 13, 2004 | 07:16 AM
Jimbare's Avatar
Jimbare
all alone in the world
the one you bought is a borgwarner tranny. good tranny. it and the new process are about the same as far as strength and gearing, but it is a differant tranny. the holes may already be in the frame for the crossmember braces. good luck!
Old Mar 13, 2004 | 10:42 AM
bremen242's Avatar
bremen242
Like jimbare said, most crossmembers have sliding holes in the crossmembers and different holes in the frame. However, I think you'll find that the tranny mounts will be in different places on the tranny itself. They normally hit pretty close.
Old Mar 13, 2004 | 12:15 PM
82F100SWB's Avatar
82F100SWB
You shouldn't need to do anything with the crossmember. You may have to turn the mount itself around(they are offset).
Old Mar 13, 2004 | 12:24 PM
bremen242's Avatar
bremen242
I don't think you can flip the crossmembers in a 4wd because of the drop down lip for the front driveshaft? I know the 2wd you can.. Unless I wasn't paying attention when I was swapping ends on my f-250 when I was putting in the crossmember..
Old Mar 13, 2004 | 12:43 PM
82F100SWB's Avatar
82F100SWB
I'm not referring to the crossmember, but the rubber isolator itself, the studs are offset in it.
Old Mar 13, 2004 | 03:22 PM
bremen242's Avatar
bremen242
oic.. I didn't know they were offset.. I'll have to look at mine..
cr8zy_vws
Feb 15, 2011 05:11 PM
wtroger
Jan 19, 2011 04:15 PM
Gary Graham
May 8, 2007 07:54 AM
stargazer
Sep 25, 2003 09:32 PM
