How do you prime oil pump?
Old Mar 12, 2004 | 10:38 PM
Skagit's Avatar
Skagit
When and how do you prime a 460 oil pump? I am dropping a 460 in my bronco and I am chainging the oil pickup and heard I may need to prime the pump. What is the method for this? The motor has been sitting fo about 1 year, it is out of a 77 f250. Thanks.
Old Mar 12, 2004 | 11:34 PM
Mil1ion's Avatar
Mil1ion
Electric drill with a 14"long hex socket (matches the dizzy shaft bottom) and spinna-rama
Old Mar 13, 2004 | 02:21 AM
mark a.'s Avatar
mark a.
Just spinn it over with the plugs out till the press. comes up then start it it's not that fragile.
Old Mar 13, 2004 | 08:25 AM
c_rossman's Avatar
c_rossman
Make sure you spin the drill in reverse. I also like to tape the socket onto the extention so it doesnt get dropped into the motor if it comes off.
Old Mar 14, 2004 | 12:28 AM
bigsnag's Avatar
bigsnag
Yes, counterclockwise.
Old Mar 14, 2004 | 01:44 PM
weldingfreak's Avatar
weldingfreak
I was always told to put vasline in the gears before assembley so the pump will not suck air and provide lube for the gears. You should change oil after engine work like that anyway. That is what i was told in tec. school any way.
Old Mar 14, 2004 | 01:54 PM
bigsnag's Avatar
bigsnag
I think I would put in some moly assembly lube, but not vaseline. I don't even know what the heck that stuff is.
Old Mar 14, 2004 | 02:37 PM
c_rossman's Avatar
c_rossman
Petroleum Jelly, Its what all the manuals say to do
Old Mar 14, 2004 | 04:07 PM
weldingfreak
Thank you (c_rossman) I had hoped I was not told wrong about the Petroleum Jelly
rustoleum82
Sep 2, 2016 08:04 AM
Tyler S
Aug 6, 2013 03:30 PM
dyoungen
Oct 27, 2012 09:14 PM
BinfordToolman
Sep 7, 2010 07:09 PM
TOPS
Oil & Lubrication
18
Oct 24, 2009 04:36 AM
