fuel gauge sender
Old Mar 12, 2004 | 09:37 PM
skeneguy's Avatar
skeneguy
fuel gauge sender
If a fuel gauge (1989) goes off the scale is it an open circuit or grounded? any ideas?
Thanks
Old Mar 13, 2004 | 08:25 PM
Timken's Avatar
Timken
If you are talking about when you fill up, it usually goes past the marks on the dash face. Otherwise it can mean that it is grounded, this is one way you ck to see if the dash unit and the wire is good, touch the wire to a ground to see if it moves the dash needle.
Old Mar 14, 2004 | 12:04 PM
skeneguy's Avatar
skeneguy
It was a new rear tank and sender unit put in, the needle pegs out as soon as the ignition is switched on. After looking at a wiring diagram, it looks like there is an inadvertant ground somewhere and the gauge ground it not being controlled through the sender rheostat. I though maybe the tank has to be isolated from ground, but after checking another truck, that doesn't seem to be the case.
Old Mar 17, 2004 | 04:09 PM
82F1507.5's Avatar
82F1507.5
I have fought this problem many times on other Ford trucks with dual tanks. I still am not absolutely sure how I fixed them each time but after changing the pump/sending unit, the fuel gauge would go way past full and stay there until a considerable amount of fuel was consumed, then it would start working. Yes, I made sure it was the correct pump/sending unit.
I seem to remember that there is a baffel (anti-slosh) built into the tank and it is possible to scrape this with the level sensor during installation. I did remove and replace the same units until I got them right, and I also remember spending way too much time at it.
Old Mar 19, 2004 | 06:49 AM
jrocco's Avatar
jrocco
If the gauge is going full scale then you have an open circuit.
Old Mar 19, 2004 | 09:30 AM
skeneguy's Avatar
skeneguy
Thanks for the replies. I had to drop the tank again, it was an open circuit.
theerod
15
Mar 30, 2023 09:26 AM
tjustice
Jul 23, 2012 08:42 PM
AlM
1978 - 1996 Big Bronco
Sep 5, 2010 09:49 PM
Steve91
Dec 6, 2002 10:08 PM
otto
Mar 8, 2001 11:06 PM
