vaccum nightmare
Old Mar 17, 2004 | 12:07 PM
mx985's Avatar
mx985
Unhappy vaccum nightmare
1982 f150 straight 6 4.9L
I bought this truck already torn appart with a bad head.
A new head has already been installed along with a complete carb overhaul. my only problem know is the last guy riped all the vaccum lines off and they all broke and cracked. and all i have to go off is the diagram in the front of the eng comp. but every thing is abr.
the letters on the carb are: EGR, 3, S, E, VDV, TVV, BV, WOT
other letters on diagram I do not know what they represent:
TVS, VCV, BPL, A/CL DV
Does any one know what they represent?
can I block some of them off and call it good?
which ones are important?
Old Mar 17, 2004 | 01:42 PM
82F1507.5's Avatar
82F1507.5
Look on eBay for your EVTM manual. It has all the codes, colors, routings,exploded views etc... I paid $20 for mine.
EVTM= Electrical and Vacuum Troubleshooting Manual.
This tool is a must have!
Old Mar 17, 2004 | 07:19 PM
5_labsownus's Avatar
5_labsownus
EGR = Line to the EGR valve
3 = ?
S = Spark advance
E = Emmisions
VDV = Vacuum delay valve, A small round device in the vacuum line.
TVV = Thermal vacuum valve
BV = ? Possible "Carb bowl vent valve"
WOT = Wide open throttle valve, Mounted on the front right side of the carb.
TVS = Temperature vacuum switch
VCV = Air Cleaner vacuum control valve
BPL = ? Possible "Backpressure Transducer
A/CL DV = Air Cleaner duct vacuum valve
If you valve cover has a tag on the front that has a bunch of numbers, that is the "Calibration label". I need the long number on the top and on the right, the numbers after "C". "R" and "S".
I will send you a photo of the diagram!
Old Mar 19, 2004 | 11:23 AM
mx985's Avatar
mx985
thank you for your response, this informaition is very valuable.
THE NUMBERS ON THE ENG. ARE
E2AE-9C485-AFA
CFM 4.9 TIA DFS
CARB NUMBER
E2TE MA A1K14
tommythomasson
26
Mar 27, 2023 09:29 AM
shotgun2
Nov 19, 2016 10:32 PM
ThoobHertz
2009 - 2014 F150
Jun 19, 2016 10:32 AM
70f250highboy
May 20, 2015 07:58 PM
