Temp Gauge Not Working...
Old Mar 12, 2004 | 02:49 PM
KeelarPluto's Avatar
KeelarPluto
So I am driving today on a back country road and after getting myself out of a small mud hole I realise that my temp gauge has gone flat.....I have the 302 in my truck.....Upper Radiator Hose is hot and heater blows hot air? What did I do to it now?
Old Mar 12, 2004 | 03:06 PM
frederic's Avatar
frederic
If you put the key into the "run" position, without the truck running, and take the wire off the water temp sensor and touch it to ground, the temp gauge should swing wildly over to "HOT". If it doesn't, bad gauge. If it does, replace sensor.
Old Mar 12, 2004 | 11:27 PM
KeelarPluto
Fred...Thanks for the reply...Where can I find the Water Temp Sensor? It's still safe to drive my truck so long as I check temp every once in a while, IE. look under hood and feel hoses etc? Im a newbie, LOL
Old Mar 13, 2004 | 12:09 AM
acerockola77's Avatar
acerockola77
You'll be fine, as long as there's no smoke comming from the engine compartment
Old Mar 13, 2004 | 08:04 AM
frederic's Avatar
frederic
Mike,
While the guy who posted just above mine seems to be a comedien, he is right actually. You can drive without your gauge working, no problem.
The sensor is on the intake manifold, its essentially a threaded metal cylinder with a nut-shaped collar on it, with one wire going into the center of the part that sticks up.
If you take it out to replace it, always use a strip of teflon tape on the threads before putting it back in. Any home depot, hardware store, plumber's supply will have teflon tape.
Its actually not tape, its just plastic with teflon impregnated into it. But it seals the threads well. Don't use any kind of "goo".
Old Mar 14, 2004 | 12:47 AM
KeelarPluto
Fred.....Thanks for the replies, I have one of those Chilton books...I'll look in the book exactly where this thing is....Anything I need to know about it and what do I need to remove off my motor to get at, if anything?
bowhunter96
Sep 15, 2021 07:05 AM
arrowheadfred
Jul 1, 2011 12:41 AM
capt g
Jan 19, 2007 12:49 PM
Forddeiselonly
Jul 31, 2004 09:28 PM
