axel ids
Old Mar 11, 2004 | 11:04 PM
mountainhoundf350's Avatar
mountainhoundf350
axel ids
hey guys just curious what the axels/diffs would be in my 04 f350 psd 4x4. thank you in advance.
Old Mar 11, 2004 | 11:12 PM
Boss_358's Avatar
Boss_358
Is it a SRW or a duallie? Front is definately a dana 60. If it is a single rear wheel it should be a Visteon 10.75. If it is a duallie, it should be a Dana 80. If you need more info, post what your diff tags read.
Old Mar 12, 2004 | 08:55 AM
mountainhoundf350
boss_358 it's a srw. it is not a visteon/sterlin looks like a dana. thanks.
Old Mar 12, 2004 | 09:08 AM
78fordman's Avatar
78fordman
It is a sterling 10.25 or 10.5 something like that. Ford done away with rear srw dana a long time ago.
Old Mar 12, 2004 | 10:16 AM
Boss_358's Avatar
Boss_358
mountainhoundf350, can you get the numbers off of the tag just to make sure? It is possible that Ford could have started using Dana axles on the SRW again. But 03 still used Visteon axles so it would seem kind of odd. Even a pic in your gallery would help. If Ford is using Dana's for that application again that would be news to me. I would think if they did, at least they would use something a little heavier like a 70.
Old Mar 12, 2004 | 12:31 PM
mountainhoundf350
driveway is a bit muddy right now but i wiil try and get under it this afternoon. my f150 had a sterling. my 86 f250 also. this one does'nt look the same. it does look like the dana axels. i will get the #s though this afternoon.
Old Mar 13, 2004 | 03:48 PM
mountainhoundf350
boss_358 here are those #s
v 720 f
73 10 5 4A09
Old Mar 13, 2004 | 06:54 PM
SoCalDesertRider's Avatar
SoCalDesertRider
As far as I'm aware, your rear axle should be a Ford Sterling 10.50" and your front axle should be a Dana 60 high pinion with reverse cut gears and ball joints. Ford switched from the 10.25" to the 10.50" Sterling with the new Superduty trucks. The Sterling axle does have kind of a similar shape to the cover as a Dana axle, I can see where the two could be confused.
Old Mar 14, 2004 | 11:27 AM
Boss_358's Avatar
Boss_358
v 720 f
73 10 5 4A09
mountainhound, looks like a couple of numbers were left out. The bottom row should read 3.73 or 3L73 10 5 4A09. The 10 5 indicates that you have a Visteon 10.5 axle. Socal is right, they do somewhat resemble a Dana axle, but not completely.
Old Mar 14, 2004 | 03:08 PM
mountainhoundf350
no boss thats all the #s thanks. so what do the new sterling change the diff cover becuase my other ones did'nt look at all like a dana. oh it is a 3.73 no l/s
slk133
20
Jul 14, 2012 03:55 PM
mrdoughnut
Jan 9, 2012 02:13 PM
fastbug
Aug 10, 2009 09:24 PM
ronchier1
1997 - 2003 F150
Jun 19, 2005 08:21 PM
