spline count please front HP D44
Old Mar 13, 2004 | 07:39 PM
nickm's Avatar
nickm
Any one know the spline count for a stock 78 ford crew cab HP D44 leaf spring set up with 5X5.5 bolt pattern?
I am going to get one from a bone yard tuesday. What rear came in that truck also.
Thanks
edit: Its an F150 or 100 not a 250
Old Mar 13, 2004 | 08:53 PM
Phinxter's Avatar
Phinxter
I looked in a catalog, and it appears Dana 44's used 30 spline axles. Hopefully somebody can verify this.
Old Mar 14, 2004 | 10:13 AM
Ford79's Avatar
Ford79
That truck has (as do all hp D44's) 30 spline inner shafts and 19 spline outers. That truck should also have a 9" rear with 31 spline axles and they both most likely have 3.50 gears in them(thought they could be different) Look for a tag under one of the bolts on the front or rear housings, it will have the gear ratio from the factory on it. It is also is most likely a super cab, not a crew cab(4 doors), I don't believe there ever were 4 door F-150's.
Old Mar 14, 2004 | 05:54 PM
nickm's Avatar
nickm
thanks it does have 30 spline. And it is a super cab. I belive you are correct I have never seen a '70ish 4 door 150 either.
I ordered a complete rebuild/install kit, ujoints, 4.56 gears and ball joint for $385. Was that a good deal?
