94 Explorer Problem
Old Mar 10, 2004 | 07:45 PM
savvy5473's Avatar
savvy5473
94 Explorer Problem
I am having trouble with my Explorer. Runs very rough when accelerating but idles very smooth. I replaced the fuel pump as pressure was low but that has not fixed the problem. I have run the trouble codes and got a PIP (Pick up Induction) Sensor Circuit Failure and a Cylinder Identification Circuit Failure. Can someone help me. I though it might be the PIP sensor which sits on the Distributer shaft but the FORD dealer says he has never seen a pip sensor go. Can someone help! This is a 4.0 Litre engine. 1994
Old Mar 10, 2004 | 11:53 PM
mrshorty's Avatar
mrshorty
Run a search on this forum back to last summer for "gtest.pdf" Ther you will find a complete list of codes (for a '95 Explorer, but will be almost identical to your '94 except for tranny codes) and circuit "pinpoint" tests.
Old Mar 11, 2004 | 02:07 PM
savvy5473's Avatar
savvy5473
I already have the codes. I am looking to find out if the problem may be this PIP sensor or maybe something else?
Old Mar 11, 2004 | 02:15 PM
savvy5473's Avatar
savvy5473
The actual codes are
211 - Profile Ignition Pickup (PIP) Circuit Failure
214 - Cylinder Identification Circuit Failure
Old Mar 11, 2004 | 03:38 PM
mrshorty's Avatar
mrshorty
Here's the first step in the circuit test for a 211. The rest of the circuit test and the circuit test for the 214 will be in that file I mentioned above.
To prevent replacing good components, be aware
following non-EEC related areas may be at fault:
* Ignition Control Module (ICM).
* Ignition coil packs.
* Spark plugs and/or wires.
* Crankshaft Position (CKP) sensor.
* Secondary ignition short to ground.
This test is intended to diagnose:
* IDM Wiring harness circuits.
* Powertrain Control Module (PCM).
1) Continuous Memory Code 211: Erratic Ignition
Code 211 indicates 2 successive erratic Profile Ignition
Pick-Up (PIP) pulses occurred. Possible causes for this fault are:
* Loose wires or connectors.
* On-board transmitter equipment (2-way radio).
Repair any problems found, and repeat QUICK TEST. If problem
is not found, go to step 4). If vehicle does not start, go to
CIRCUIT TEST AC.
Dirtydan1213
Jul 4, 2017 03:01 AM
Scott54321
21
Oct 3, 2013 05:28 PM
cookie88
Bronco II
13
Sep 18, 2007 05:31 PM
Flatlanded87
May 9, 2007 06:39 PM
nitro169
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 7, 2006 02:11 PM
